Author Topic: Show us your electric fuel pump switch locations!  (Read 3019 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: March 02, 2015 - 06:56:10 PM »
I have a green lit switch for my Mallory fuel pump and I am now wondering where is a good place to mount it yet not drill a hole in the dash.
I want to keep it clean and nice and I was thinking of mounting it low like the lower part of the dash just above the console.
Thoughts, ideas, pics?
My pic will be uploaded when the admins clear the upload folder. :P
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Show us your electric fuel pump switch locations!
« Reply #1 on: March 02, 2015 - 07:36:12 PM »
I mounted mine under the heater controls to the right of the e-brake lever.  It was hidden for the most part yet easy to access when starting the car.
Offline GoodysGotaCuda
« Reply #2 on: March 02, 2015 - 08:21:43 PM »
I had a switch drilled into the windshield washer foot pump mount for awhile. It was well hidden and relatively easy to flip if I wanted to.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: March 03, 2015 - 02:00:56 PM »
Here is my idea, which I believe jives with what one of you said.
« Reply #4 on: March 03, 2015 - 02:09:24 PM »
Does your car have a MAP light?  If so, do you think you'll ever use it?  I'd hook the pump up to the map light switch.  If you don't have the map light, I would try to find a map light bezel and install the switch in the same location.  There should already be a hole in the dash for it.  That would be my first choice.
It looks like you might already have your gauge pod mounted where the map light switch was originally mounted though.  Is this electric pump going to run all the time or just used to prime the engine after the car sits?  Post a picture of your switch.  Since you have a custom interior, I think a switch might look good on the console...directly in front of the shifter.  You'd only have to drill a hole into the top plate.  Obviously, it depends on what the switch looks like.
« Last Edit: March 03, 2015 - 02:20:28 PM by burdar »
Offline marc70challenger
« Reply #5 on: March 22, 2015 - 01:39:53 PM »
Same here.   :drunk:
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Offline roadman5312
« Reply #6 on: March 22, 2015 - 04:57:04 PM »
Why not just eliminate the switch, wire the relay to trigger directly from the ignition switch.
Offline MirageCuda
  • 1974 Cuda
« Reply #7 on: March 22, 2015 - 11:18:58 PM »
So it's harder to steal your vehicle?   :dunno:
Randy
1974 Plymouth Cuda
2006 Dodge Ram 1500 SLT
1991 Nissan Skyline GTR
2002 Subaru Impreza WRX
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: March 22, 2015 - 11:25:20 PM »
I have done that on another car and like the fact that I can turn on and off the pump when I want.
For example, if you want more juice to start the car. Turn off the pump after you have enough in the floats and then once started - turn it back on.
Just gives you more options - that's all.
B
Offline dfrazz
« Reply #9 on: March 23, 2015 - 08:44:52 AM »
Yes, and there are times when you will be working on your car and require the ignition switch to be on but do not want to run the pump.
« Reply #10 on: March 23, 2015 - 09:28:57 AM »
So it sounds like this pump will be running all the time?  I'm thinking of adding a pump just to prime the carb after the car sits.  Today's gas evaporates out of the carbs pretty fast.
Offline dfrazz
« Reply #11 on: March 23, 2015 - 09:32:40 AM »
If this pump is used in place of the mechanical pump, it will need to run when starting and running the motor.
Offline Oldschool
  • Member Since 9-05-06
« Reply #12 on: March 23, 2015 - 11:03:11 AM »
You can't actually see the switch, but it is mounted in the shifter console, just to the left of the shift lever. It is the front switch out of 4 flip switches mounted there.
1) - Fuel Pump
2) - Water pump
3) - Left cooling fan
4) - Right cooling fan
Ken  --  In Georgia
