Author Topic: Stripping paint from 73 challenger header panel  (Read 1020 times)
Offline dave73chally
« on: March 03, 2015 - 05:19:36 PM »
I need to strip the paint off the header panel on my 73 challenger. What is the best way to do this since its fiberglass? Was thinking of looking for a local shop that does soda blasting, is that recommended?
73 Challenger
Re: Stripping paint from 73 challenger header panel
« Reply #1 on: March 03, 2015 - 07:04:14 PM »
Absolutely DO NOT media blast fiberglass.
Chemicals can be used, these guys have several ideas  http://www.corvetteforum.com/forums/c1-and-c2-corvettes/2813678-stripping-old-paint-from-fiberglass-corvette.html
Offline jimynick
« Reply #2 on: March 03, 2015 - 10:37:19 PM »
We always used a gel stripper back in the day on all the Vette's we did. As mentioned, wash it off afterwards with thinners and then we'd sand the glass with 120 to give it some "tooth" for the primer. Watch the stripper (no puns intended) because the tiniest spec will burn you. Wear protective gear AND eye protection for sure!  :cheers:
« Reply #3 on: March 04, 2015 - 12:15:12 PM »
Do you HAVE to strip it?  On my car, they just lightly sanded it and feathered out any of the rock chips.  If you have a lot of paint layers on it then it's another story.
« Reply #4 on: March 04, 2015 - 01:19:33 PM »
There's 2 paint layers at the least that I can tell. The top layer has been chipping away causing 2 different paint heights. I figured my best bet was to strip it down completely.
73 Challenger
« Reply #5 on: March 04, 2015 - 01:22:47 PM »
I'm thinking I'll just sand it. What grit would you recommend I start with and taper down to?
73 Challenger
Offline jimynick
« Reply #6 on: March 04, 2015 - 07:08:19 PM »
Can you sand the chocolate chips out of a cookie?  That's not too far off as an analogy here. The paint'll be harder than the 'glass and it's right tricky to avoid chewing the 'glass up. If you're bound and determined, I'd use 120 and see how that cuts/works for you. If you only want the paint off the flats, try a DA sander but mind your manners with it. Good luck
