Author Topic: Steering coupler seal retaining clamp  (Read 3737 times)
« on: March 04, 2015 - 04:33:17 PM »
Didn't even know this existed. That seal design drives me nuts! :pullinghair:  This looks like it would help. I noticed a lot of others have the same problem , thought I'd share this!
http://www.ebay.com/itm/Rare-Mopar-2996935-Steering-Coupler-Retaining-Clamp-most-62-80-Dodge-Plymouth-/301416193929?pt=Motors_Car_Truck_Parts_Accessories&hash=item462dce1f89
Offline WildJones
Re: Steering coupler seal retaining clamp
« Reply #1 on: March 04, 2015 - 05:05:57 PM »
Brad, I think someone posted this a week or two back and said it doesn't fit for our e bodies. Do a search before spending $, i may have misunderstood.
95682
1970 Cuda
« Reply #2 on: March 04, 2015 - 05:08:29 PM »
They just started reproducing these.  They used to be available back in the 70's and 80's.
How close do the couplers get to the header tubes?  Would these clips interfere?  There is also a redesigned coupler seal that does away with the original metal retainer.  The new seal is larger and slides down over the coupler body.  They aren't cheap though.
« Reply #3 on: March 04, 2015 - 05:10:43 PM »
Yes it wouldn't work for me, too close to the header. Post up a link to the new design seal your talking about, someone might find it useful?
Hummm missed it
Offline roadman5312
« Reply #4 on: March 04, 2015 - 05:34:13 PM »
I think another thread said its a real pain to get it on. We got one, probably try install about a month. Still in BODY SHOP JAIL.  :(
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #5 on: March 04, 2015 - 06:27:40 PM »
I just made a tool to crimp the tabs correctly like the factory did  :bigsmile:
Offline Katfish
  • 70 Challenger
« Reply #6 on: March 04, 2015 - 06:42:14 PM »
I bought 1, but gave up trying to get it on.
If anyone succeeds please post the results.
Granted, I didn't spend a lot of time, but that sucker doesn't just pop on.
Offline DAYLEY/CHALLENGER
« Reply #7 on: March 04, 2015 - 08:31:27 PM »
That metal cap is  a pita.  Have tries several times to crimp. .    Right now it's just on the shaft.  It can't fall off... :stomp:
Dave or David
« Reply #8 on: March 05, 2015 - 09:42:50 AM »
Steer and Gear makes the updated seal. #2111
http://www.steerandgear.com/Chrysler_Catalog.html#TXTOBJ7DB1219F302938E1
To get the stock style retainer installed I used two pieces of 1x6.  I drilled a hole in one of the pieces...that piece went on the top side of the coupler.  The uncut piece went on the bottom of the coupler.  I used some C-clamps on the two pieces of 1x6 to hold pressure against the retainer while I used a chisel to bend over the tabs.
Offline stinger
« Reply #9 on: April 20, 2015 - 08:44:48 PM »
mine fits after a little adjusting with a hammer and a vise.. :horse:
« Reply #10 on: May 16, 2015 - 09:15:05 PM »
Put mine on today using 2 C clamps.
Offline jimynick
« Reply #11 on: May 18, 2015 - 11:24:15 PM »
By golly, you're NOT just a pretty face, are you Mike?! That's a great idea! It only took about 4 or 5 of us when we were trying to get Andy's on out in the driveway! I finally had to walk away from it, but your idea has rejuvenated my faith that it can be done.   :thumbsup:
« Reply #12 on: May 18, 2015 - 11:37:19 PM »
Thanks.
The idea came about trying using just one. Then I realized 2 would keep force equal.
Called my friend and said come over with a C clamp since I only had 1.
He helped hold it while we pinched the tabs over helped as well.
« Reply #13 on: May 19, 2015 - 09:41:42 AM »
Quote
That's basically what I did...except I used wood instead of metal to clamp against.  Be careful and don't clamp too hard.  The first time I did it, I clamped so hard that the retainer cut through the rubber boot.
« Last Edit: May 19, 2015 - 09:43:31 AM by burdar »
