Author Topic: Finally... ordered a 4 Post Lift  (Read 18091 times)
Offline Gumby
Re: Finally... ordered a 4 Post Lift
« Reply #60 on: March 15, 2015 - 07:47:09 PM »
I would have tested it with a couple of hondas first time, lol. FANTASTIC! Good job!
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
« Reply #61 on: March 24, 2015 - 03:29:03 PM »
Looks great! I'm sure you will get lots of use out of it.  :2thumbs:
Offline Fred
« Reply #62 on: March 24, 2015 - 06:16:34 PM »
That's great!  Contrats!  Thanks for sharing.
Do you know if there is a way to put cross members to lift car, remove wheels, then lift up?
Offline Racer57
« Reply #63 on: March 24, 2015 - 10:09:52 PM »
There is a separate hyd unit that slides along the ramps edge that be bought for that.  http://www.gregsmithequipment.com/Atlas-RJ-35-Sliding-Jack
Offline CudamanTom
« Reply #64 on: March 29, 2015 - 06:56:20 PM »
Thanks Fred.
There is a heavy duty (jacking) tray that came with the lift and I plan to use a hydraulic bottle jack to lift certain areas when needed. That lift that Racer mentioned is great but man it's expensive. But it is nice...
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline CudamanTom
« Reply #65 on: March 29, 2015 - 07:00:58 PM »
Well this weekend I finished what I started. I cut the 2x4 going across and loosened the wiring so I could raise the lift enough to walk under it without having to duck or bend over to go under it. Big difference. Cleaned up the shop a little too.
 :2thumbs: :bigsmile:
Oh, I also bought a 2,500lb winch I plan to attach to the front of the lift for cars that can't drive on the lift.  :cheers:
« Last Edit: March 29, 2015 - 07:10:49 PM by CudamanTom »
Offline Finoke
« Reply #66 on: March 29, 2015 - 07:22:43 PM »
Oh yeah, that's what I'm talkin bout  :bigsmile:
Offline Cruzin
  • I love YaBB 1 Gold!
« Reply #67 on: May 29, 2015 - 09:35:20 PM »
Just curious what is the measured height, to the roof of the Cuda?
I'm contemplating a 4 post lift too.  Thanks for sharing.
Offline ToxicWolf
« Reply #68 on: May 29, 2015 - 10:09:02 PM »
I like it  :droolingbounce:
Offline CudamanTom
« Reply #69 on: May 30, 2015 - 11:46:35 PM »
Sorry for the delay.
At a height of 80" measured at the top of the lift runner (where the tires rest on the lift), the roof of the cuda measures roughly at 11' 6" from the floor.
I give a  :2thumbs: on this lift or at least a 4 post lift with caster options to move around.
Hope that helps.
Tom
Offline HP_Cuda
  • Mopar or No Car!
« Reply #70 on: May 31, 2015 - 06:37:11 PM »
I kept trying to figure out how you got the Green Cuda sideways and then I saw the casters.
For a minute there I thought you had cut a hole in the side of your building!   :roflsmiley:
 :2thumbs:
Offline CudamanTom
« Reply #71 on: May 31, 2015 - 06:41:41 PM »
 :2thumbs:
Bryan, that would have been plan B if casters weren't part of the deal.  :smilielol: :bigsmile:
