Author Topic: Clutch pedal stop !?!  (Read 4046 times)
Offline Racer57
« on: March 05, 2015 - 06:07:01 PM »
Didn't know this stop was on the pedal until today. I suspect the installer of my Tremec 500 did it and neglected to tell me. Anyone seen this done before ?   It had been tearing up my floor mats so I'm gluing a piece of rubber hose to it.
Offline anlauto
Re: Clutch pedal stop !?!
« Reply #1 on: March 05, 2015 - 06:32:41 PM »
Why ? :screwy:
Offline shawge
  • Zoiks!!
« Reply #2 on: March 05, 2015 - 07:21:37 PM »
Do you have a hydraulic clutch and Wilwood master cylinder?  The Wilwood master cylinder can only handle only 1.4" of travel before the seals are broken.  I have the Wilwood MC and had to add a stop - the travel was right at 1.5".  Came up with a solution using one of the bolts on the clutch MC brace, some washers, and a rubber table leg pad.
- Jerry
« Reply #3 on: March 05, 2015 - 09:38:45 PM »
so you do not overthrow the pressure plate , I assume it has the diaphragm clutch & the leverages are all wrong
Offline Racer57
« Reply #4 on: March 06, 2015 - 08:57:13 AM »
It does have a diaphragm clutch. I had suspected that the length of the travel might have been an issue.
Offline 73restomod
« Reply #5 on: March 06, 2015 - 09:33:08 AM »
I would suggest making a bracket that bolts up to the pedal assembly, with a bolt or section of threaded rod with a locknut. That way you can adjust the travel under the dash where it will not be an eyesore.
Offline Racer57
« Reply #6 on: March 06, 2015 - 02:44:12 PM »
I am considering making a stop like you suggest. But anyone that sees whats there now has to be a contortionists. :D
« Reply #7 on: March 06, 2015 - 08:28:26 PM »
you could mount a stop on the floor too
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #8 on: March 07, 2015 - 09:29:14 AM »
Most of you have probably seen Aaron Beck's Kuda build... Check out his Blog. http://beckkustoms.blogspot.com/search?q=clutch+pedal+stop
He fabbed this clutch pedal stop. This man does amazing work!  :drool: :ylsuper:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline Brillo1974
« Reply #9 on: December 25, 2015 - 09:04:27 AM »
So is this an issue with a diaphragm clutch? I just bought one from Brewers for my 4 speed swap and glad I was snooping here some more on everything before I start. Do I need a stop on the pedal so I don't F something up? I could weld an adjustable  stop at the top of the pedal before I put it in if that's the case.
Trump.... The Voice of the AMERICAN People!
« Reply #10 on: December 25, 2015 - 09:24:25 AM »
The car is set up for a 3 finger B&B style clutch the diaphragm uses a different ratio so less travel is usually required , hyd clutches also often require different travel so adding a stop of some sort may be nessisary to make everything work
Offline Brillo1974
« Reply #11 on: December 25, 2015 - 12:29:49 PM »
Yep as most of the time, new and improved is not always better.  :pullinghair:
