Author Topic: Biggest Tire I can run on my 70 Challenger  (Read 8705 times)
Offline 69CHARGERMD
« on: March 05, 2015 - 07:41:26 PM »
70 Challenger  :ylsuper:
I am installing a DANA from Dr Diff ( that was made for a B body ) so I can get more clearance. ( stock wheel wells, no mini-tub )
I have the 1.5" off set hangers and shackles he provided.....
If I recall, he mentioned I could run a 10" rim with 5.5" of back spacing
Is anyone running any of the listed tire sizes ??
- 295/65/15 (Drag Radial) ?
- 29/12/50/15 Hoosier Prostreet radial ?
- 28/12/15 MT Sportsman SR Street radial ?
Pic's would be great....
I want to stuff a BIG tire under the car, that is the reason I went with the B body DANA and offset hangers, etc.
thanks
Doug  :thumbsup:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline dave73chally
Re: Biggest Tire I can run on my 70 Challenger
« Reply #1 on: March 05, 2015 - 07:48:35 PM »
 :popcorn: I'll be going with the dr. Diff 1.5" kit in the future also. Want to know how wide I'll be able to fit on a 17/18" wheel
73 Challenger
Offline 69CHARGERMD
« Reply #2 on: March 05, 2015 - 08:14:12 PM »
Dave,
Dr Diff ( Cass ) was great to work with......
I got the DANA, offset kit, rear ( and front ) disc set up from him,,,
very friendly, and helpful over the phone...
What differential do you have in the car now ? ( i had a 8 3/4, but removed it as I proceed with restoring my car )
Doug :cheers:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline Dusty1
  • Revived
« Reply #3 on: March 05, 2015 - 08:18:53 PM »
295/50/15 B F Goodrich
Garys 1972 BS
« Reply #4 on: March 05, 2015 - 08:26:15 PM »
Dusty that looks great. How wide is your rear wheel? Do you have dr. Diff. 1.5 relo kit? I have 15x8 with a 275, want to go bigger once these are burned up.
73 Challenger
Offline 69CHARGERMD
« Reply #5 on: March 05, 2015 - 08:29:34 PM »
I have a 295/65/15 on my Charger,,,and like how it fills out the wheel well,,,,,
Dusty,,,NICE car,,,,,
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 69CHARGERMD
« Reply #6 on: March 05, 2015 - 08:31:10 PM »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
« Reply #7 on: March 05, 2015 - 08:56:08 PM »
I have 315's on 17"x10.5" rims with the 1.5" Dr. Diff offset kit.
Offline Dusty1
  • Revived
« Reply #8 on: March 05, 2015 - 09:07:22 PM »
Thanks guys! Just an 8.5" wheel with just over stock offset. Clears the springs easy, all OE.
« Last Edit: March 05, 2015 - 09:09:33 PM by Dusty1 »
Garys 1972 BS
« Reply #9 on: March 05, 2015 - 09:41:43 PM »
I have a 295 50 15 under my Chall without the narrow diff or spring offset
« Reply #10 on: March 05, 2015 - 11:05:20 PM »
I have 295/40/18 on mine with room to spare.
Offline KillerBee
« Reply #11 on: March 06, 2015 - 07:54:55 AM »
I'm going to do some experimenting with my wife's 1971 R/T Challenger this summer.
I've been collecting parts for years.
I have a 1970 B body rear end that I'm going to install with Dr. Diff's offset hanger kit.
My wheels are custom made Torque Thrust 15x10 with 5 3/4" back spacing.
The tires are 325/50-15 BFG drag radials that are listed as 28" tall 13" total width with 11.75 tread width.
I hope to tinker with some 1/4" wheel spacers and see if it will fit.
I test fitted 28x12.50 ET streets under our other stock width 1971 R/T Challenger on 15x8" rims with 4 1/2" back spacing with no problems...see pic below.
I plan to re-test fitment of the ET Streets now that the car is sitting lower.
In the bottom pic I'm using a 15x8 rear wheel with 275/60-15 street radial tires and have plenty of room.
The Dana is stock E-body width.
« Last Edit: March 06, 2015 - 12:17:25 PM by KillerBee »
« Reply #12 on: March 06, 2015 - 09:21:37 AM »
I have the same mod sheet as you; 1" inset springs, B body rear. I'm using a 15x10 wheel, 5" backspace. Currently using MT SR 26x12x15. I've got plenty of room and may consider stepping up to a 28x12 next time. My avator to the left has a 295/50x15 on 15x8, 4.75 backspace with stock springs and housing. It also fit without any issues but was kind of close to the springs.
I've put a 295/65x15 on a 15x8, 4.5" backspace. It fit in the wheel well, but the aspect ratio was way off with the rest of my combo. Didn't look too good on my car.
Offline 69CHARGERMD
« Reply #13 on: March 08, 2015 - 07:16:11 PM »
Thank you guys !!!
Appreciate all the info,,,,,,
Some very nice rides,,,,
Glad to hear a 295 or 315 fits
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 73restomod
« Reply #14 on: March 12, 2015 - 01:14:12 PM »
I have B-body rear with doctor diff 1" kit. I have 1.125"-1.5" to the leaf from the sidewall (285\40-18) with 5.75" backspace from back to front because leafs have a little V to them.
