Author Topic: No spark.  (Read 2873 times)
Offline richardmoparman
  • MOPARS,IT'S NOT A HOBBY ITS A LIFESTYLE
No spark.
« on: March 06, 2015 - 05:57:39 PM »
Went out to start Challenger and would not start.Turns over fine but have no spark.Tested from the coil to the alternator got no spark.Not a big electrical guy.Any Idea's would be greatly appreciated.Alternator,Maybe coil? :pullinghair:
Offline soundcontrol
Re: No spark.
« Reply #1 on: March 06, 2015 - 06:22:43 PM »
Do you have a voltmeter? If so check the positive side of the ignotion coil, should be power there when ignition is on.
If you dont have power there, first thing is to check the ballast resistor.
« Last Edit: March 06, 2015 - 06:30:42 PM by soundcontrol »
/ Ken
topic=108917.new#new
Re: No spark.
« Reply #2 on: March 07, 2015 - 12:44:42 AM »
Confirm you have fuel.
Not sure what 'tested from the coil to the alternator and got no spark' means.
What kind of ignition do you have?
No spark with a stock ignition, would guess ballast resistor first.
Offline ShelbyDogg
Re: No spark.
« Reply #3 on: March 07, 2015 - 04:10:27 AM »
Ballast resistor is bypassed in start position.  Put a test light on the 2 brown wires while cranking to check for voltage. Electronic ignition or points?  Pull cap, rotate engine till it is at a point where you can grasp the rotor and twist it back and forth to make a reluctor  tooth swing past the pickup's tooth. With ignition on, you should see tha spark with the coil wire on the alternator again.
My good electronic ignition boxes throw a 1/2" spark.
Re: No spark.
« Reply #4 on: March 07, 2015 - 10:57:46 AM »
Depends if it is single or dual. We need to know what ign he has first.
« Last Edit: March 07, 2015 - 10:59:37 AM by dodj »
Re: No spark.
« Reply #5 on: March 07, 2015 - 03:37:21 PM »
I have electronic ignition.No points.I tested the coil to the distributor no spark is what I meant not the alternator.So the ballast resistor could be bad?I will check it out.
Re: No spark.
« Reply #6 on: March 07, 2015 - 04:49:24 PM »
What kind of electronic ign. Is it the stock Mopar ign or aftermarket?
Re: No spark.
« Reply #7 on: March 08, 2015 - 06:35:24 PM »
It is the stock ignition.
Re: No spark.
« Reply #8 on: March 08, 2015 - 08:51:39 PM »
Tested the coil.I got 9.3 volts for a reading on the positive side.Is the voltage suppose to be higher or is that reading correct?If correct  does that mean the coil coulld be bad and needs to be replaced?Have no spark from coil to disributor
« Last Edit: March 08, 2015 - 08:56:41 PM by richardmoparman »
Offline ShelbyDogg
Re: No spark.
« Reply #9 on: March 08, 2015 - 09:13:05 PM »
I  use a spare distributor and ecu to test with.  I jut plug the pickup in and spin it by hand.
Did rotate your rotor like I suggested?
Offline Super Blue 72
    • Phil's Super Blue '72
Re: No spark.
« Reply #10 on: March 08, 2015 - 11:06:17 PM »
Re: No spark.
« Reply #11 on: March 09, 2015 - 08:33:03 PM »
Stock electronic (72-74) would be a dual ballast resistor. Did you get the 9.3vdc when you had the key in the start or run position? Each circuit uses a different resistor.
