Author Topic: options to raise clutch pedal height above floor  (Read 1121 times)
Offline 73440
« on: March 06, 2015 - 10:08:53 PM »
I would like to raise the height of the clutch pedal off the floor due to my heel hits the floor when using the clutch.
I have to hold my foot on the pedal higher than would like to.
I see options as possibly cutting the original parts to shorten and reweld, do not really want to cut original.
Are there good aftermarket that work well? Maybe a Wilwood?
Cut a hole in the floorboard so my heel clears, kidding.
What have ya'll tried?
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 4Cruizn
  • HEMI FISH
Re: options to raise clutch pedal height above floor
« Reply #1 on: March 07, 2015 - 12:26:49 AM »
How much play is there in the petal before the clutch engages?  Typically all I need to do is push the clutch in about half way before I can shift . . .
« Last Edit: March 07, 2015 - 12:28:35 AM by 4Cruizn »
Offline 73440
« Reply #2 on: March 07, 2015 - 02:06:54 AM »
I will try as you say and see exactly the point that a smooth shift can be made without pressing all the way down to the floor.
Maybe the disengagement point is off and I just need an adjustment ,  because to actually bring the pedal all the way up, you have to hook your foot under the pedal and pull up.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #3 on: March 08, 2015 - 08:47:59 AM »
Adjust the linkage so the pedal has 1" of free play at the top max & you may not need to push all the way down as 4C suggests
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: March 08, 2015 - 02:48:43 PM »
Food for thought, your mileage may vary.
« Last Edit: March 08, 2015 - 02:51:27 PM by HP_Cuda »
