741 rear
Author Topic: 741 rear  (Read 2896 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
741 rear
« on: May 12, 2005 - 04:06:34 AM »
I have a 741 rear  2.94 ratio,  can i put a different    differential in it, if so what would be a good one,           340  4 speed Thanks Terry
Btch n Blue
Re: 741 rear
« Reply #1 on: May 12, 2005 - 07:20:46 AM »
489 carrier are the preferred!! :thumbs: :thumbs:
Any bigger gear will help you... 3.55's - 3.73's - 3.91's... that will WAKE your car up!! :grinyes:
Offline 300
Re: 741 rear
« Reply #2 on: May 12, 2005 - 03:06:52 PM »
Thanks are you saying that i can use the 741 and put those gears in them,without changing to a 489,or should i find a 489. Thanks Terry.  ps with all the great help on this site , i will be able to start reso soon.
Offline MAXcuda
Re: 741 rear
« Reply #3 on: May 12, 2005 - 05:09:57 PM »
I have the same question.  I have a 741 rear with 3.91's.  I want to swap to 3.55 sure grip with the big u-joints for my future big block but unsure which carrier to use.  The difference is that the 741 has the smallest diameter pinion shaft, 742 is larger diameter, and the 489 is a tapered pinion shaft.  Randy's ring and pinon sells the whole shebang for about $1000.  I know the 489 is the "correct" chunk for the E bodies, but other than that why is it "preferred" over the 742?  Randy's charges more for the 742 than the 489.
Re: 741 rear
« Reply #4 on: May 13, 2005 - 01:53:00 AM »
there is no significant difference between the 489 & 742 except that the 489 uses a crush sleeve which is the weaker design , the sleeve can be replaced with a Ratech spacer part#4103 & then use shims like the 742 carrier making them equal in my opinion
Offline 300
Re: 741 rear
« Reply #5 on: May 13, 2005 - 03:42:47 AM »
My question ,       741 can i use that and change the diiferential ,or do i look for a 742 Thanks
Re: 741 rear
« Reply #6 on: May 13, 2005 - 04:07:00 AM »
you can usea 741 but it seems a watse to spend $$ on gears for the weaker carrier
« Last Edit: May 13, 2005 - 07:29:57 PM by Chryco Psycho »
Offline 300
Re: 741 rear
« Reply #7 on: May 13, 2005 - 01:21:40 PM »
Chryco.  I will be running a340 4 gear.  You helped me alot in post under engines  i gave you all the #,s for block , heads , intake etc . I replied in that post that i found letter 0 on heads. You said that it is a very good comb.  letter 0 , still as good a j heads.???. Please advise on 741 now that you know engine size etc. If you think 742 is the way to go i will look for one. Thanks Terry,,, new to mopar.
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: 741 rear
« Reply #8 on: May 13, 2005 - 01:25:43 PM »
gear set are extremely limited for the 471 carrier where the 472 and 489 have a much larger selection available and altho the 471 is defineatly the weakest carrier it isnt a total wimp. I have one setup that I have used on occaison behing everything from a hemi to a hot 360
Offline 300
Re: 741 rear
« Reply #9 on: May 13, 2005 - 03:24:30 PM »
Outlaw   what gear setup are you using in your 741    are they just a bolt in and forget.  i want the best combo for my 340  even posi wood be nice. any ideas. Thanks Terry I won,t be going to the track or anything. just want a nice cruiser.same as my 2 chevelles
« Last Edit: May 13, 2005 - 03:33:24 PM by 300 »
Re: 741 rear
« Reply #10 on: May 13, 2005 - 05:53:19 PM »
the 3.55 is a good all round gear
 the  742 carrier wil l ive ok behind a small block [too many memebrs to remember everyones combo , not that good !!] you won`t break it unless you use slick at the track
 The O heads are the same casting as the J heads
Offline 300
Re: 741 rear
« Reply #11 on: May 13, 2005 - 07:10:47 PM »
Thanks Chryco. i,ll be looking for some 355,s for my 741. Lots more to come as i progress with this project. Thanks again to all.  Get site Terry  ps Anybody from Ontario Canada Here.
Offline MAXcuda
Re: 741 rear
« Reply #12 on: May 13, 2005 - 09:58:56 PM »
sorry for jumping in on your thread Terry.  hope you got your question answered!
Offline mrbill426
    • All Around Mopars
Re: 741 rear
« Reply #13 on: July 12, 2005 - 10:31:28 AM »
 Got my attention, are you saying that a '742 cannot stand up to the use of drag slicks?    We plan to use slicks and are on the fence between using (we have both) a '742 or a '489
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: 741 rear
« Reply #14 on: July 17, 2005 - 11:38:09 PM »
the 741 si ok behind most engines , as long as the tires spin it will live & anahilated a 742 with slick in my Cuda but it hooked hard , I also broke 3 742/489s behind my 440 duster with slicks
