Author Topic: 741 rear  (Read 2895 times)
Offline greengochallenger
Re: 741 rear
« Reply #15 on: July 21, 2005 - 10:39:30 AM »
If i was gonna buy a new ring & pinoin, I would find a 742/489 chunk first then a gear for it.
Offline VPOINTCUDA
  • Wish she were done so I could take her out Ridin!
Re: 741 rear
« Reply #16 on: July 26, 2005 - 06:22:36 PM »
Chryco , how tough is it to go from 3.23 gears to 3.91 's, Also the rear I have has "kisser buttons " in between the axles, that tells me that the raer is out of a pre 69 vehicle , should I find another carrier, or is this one o.k? I am running a 440 , auto, 3800 stall converter, TCI trans manual shift with rev. pattern . I'm not planning on running Slicks, but that could change.
" the question isn't  when is he going to stop, but whose gonna stop him!"
Re: 741 rear
« Reply #17 on: July 27, 2005 - 02:10:04 AM »
it is easy to have 3.91 gears installed in a center section
 the clutch sure grip will be fine , the 741 carrier should live
