Author Topic: rear height options, only two for me, which one  (Read 2562 times)
Offline crash340
« on: March 08, 2015 - 04:09:54 PM »
Team, I have a 73 Cuda that I'm looking at raising the rear by around 1.5", I have two options available to me, one is have the 4 1/2 leaves re arched, the other is add another leaf under the main.
Which is my better option in regard to handling and performance?  as the car sits now the rear leaf spring sits almost flat, ride is good, cornering is ok, rear brakes lock up a little if im breaking into a corner.
Right now I'm leaning toward re arching, keeping the weight down etc. if I'm going to re arch, what info will the spring guys need to know? I assume the rear weight of the car???? does anyone know that?
Greg
73 Cuda
Brisbane, Australia
Re: rear height options, only two for me, which one
« Reply #1 on: March 08, 2015 - 04:55:13 PM »
I have always added 1 extra full length leaf under the main , raises it approx 1.25" but \I had access to a spring Mfg in our city
Offline blown motor
« Reply #2 on: March 08, 2015 - 06:36:32 PM »
I had mine re-arched. They added a leaf when they did it. They said if they don't add a leaf that the re-arching would start to sag in about three months because the old steel is fatigued.
Offline crash340
« Reply #3 on: March 08, 2015 - 10:14:51 PM »
Interesting, I have a set of main leaves to cut the eyes off so I might start with that, see where it ends up I guess, if its not to harsh I can probably leave it at that then.
Greg
73 Cuda
Brisbane, Australia
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: March 09, 2015 - 08:34:20 AM »
I had to add a leaf to my Challenger springs to get the rear up too.
« Reply #5 on: March 09, 2015 - 01:35:36 PM »
In their installed position, Mopar leaf should appear to be almost flat and adding height is actually a detriment to handling and alignment. However, with that said and they desire to get some more space under it, I'd go with the add a leaf first. This should give a slight lift while increasing the spring rate to produce an overall improvement in both lift and feel.
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: March 09, 2015 - 01:47:06 PM »
Do you know what the ride height is off hand (say from the ground the middle of the wheel arch)?
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline crash340
« Reply #7 on: March 09, 2015 - 03:33:41 PM »
Thanks HP2, that was my understanding of Mopar rear springs as well for handling and so on, hence my asking.
Jas, right now I have 24 1/4" all round fender lip to floor. I dont want to lower the front any more but would like to just slightly change the stance of the car by raising the rear a smidge.
here is a photo from the weekend at a car show
Greg
73 Cuda
Brisbane, Australia
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: March 14, 2015 - 07:13:36 PM »
Thanks man,  Mine currently sits at 29 inches at the rear wheel lip.  I want to drop it down a bit.  I like the look of yours now.
Jason
74 'cuda 360/727
« Reply #9 on: March 14, 2015 - 07:21:55 PM »
 :2thumbs: I like the way it sits now. I wouldn't raise the rear any more.
Looks good Crash
Offline crash340
« Reply #10 on: March 14, 2015 - 07:42:31 PM »
Thanks Dodj, I plan on fitting some 18" diam wheels with 27" diam tires so slightly taller tyres, I would like to raise the front a 1/2-1" for header clearance and the rear  a full 1" so to look at it the rake should not change much, that said, I like a Cuda with the trunk line level not sloping back like mine is right now.
Greg
73 Cuda
Brisbane, Australia
