Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Tach waring question
« previous
next »
Print
Pages: [
1
Author
Topic: Tach waring question (Read 1685 times)
67vertman
Sr. Resident
Member since 9-23-2005
on:
March 08, 2015 - 11:48:41 PM »
I just got through changing my standard dash to a Ralley dash, I am running an MSD ignition and EFI ECU. The white wire from the MSD is running to the ECU, do I run the tach wire to the MSD white wire or directly to the negative side of the coil?
Thanks,
Last Edit: March 09, 2015 - 11:06:21 AM by 67vertman
Logged
Current ride - 1970 Barracuda 440-6 4 sp Dana 60 (4:10)
Moparal
Permanent Resident
Re: Tech waring question
Reply #1 on:
March 09, 2015 - 12:39:52 AM »
Msd has all their dirrections on line, but the white wire if for points when running specific settings. IT ISNT USED IN ecu THAT i KNOW OF. I know when I run a crank trigger and retart box, the white wire is hooked to the retard box. are you sure it doesnt go to the box itself? tach wire that is.
Logged
67vertman
Sr. Resident
Reply #2 on:
March 09, 2015 - 10:54:21 AM »
It has been a couple of years Alan, so I am not sure what it conencts to on the ECU...I thought tach. I will have to check, thanks for the reminder that it is on line, my old brain didn't remember that.
Logged
67vertman
Sr. Resident
Reply #3 on:
March 09, 2015 - 11:05:37 AM »
All right Alan, I checked MSD website, and you are correct the white wire is for the crank/didtributor trigger, i should have remembered that
. There is a tachcometer port on the MSD unit.
I will try that, it says I may need an adaptor, if the tach dosn't work correctly.
Logged
maddawg57
Jr. Member
Re: Tach waring question
Reply #4 on:
March 09, 2015 - 02:06:49 PM »
I'm running a Msd 6A and MSD dissy, and had to use a adapter for the tach to read right
Logged
67vertman
Sr. Resident
Reply #5 on:
March 09, 2015 - 10:40:15 PM »
Quote from: maddawg57 on March 09, 2015 - 02:06:49 PM
Thanks Maddawg57, I am running the MSD and Mallory Dissy but through an FAST ECU. Did you run you tach wire straight from the MSD? I am going to give it a shot, and if it doesn't work I will contract MSD and get an adapter.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
