Author Topic: What size radiator ?  (Read 6682 times)
Offline 71gogreen
Re: What size radiator ?
« Reply #15 on: March 15, 2015 - 10:16:17 AM »
How do you start a new Topic? It.s a pain in the ass to navigate thru to find!!!!!! :smokin:
71challenger-millcreek park\71challenger-millcreek
Offline Priesty
« Reply #16 on: March 16, 2015 - 02:31:37 AM »
put a mark on the damper 2 3/8" clockwise from the TDC mark & that is 36*
OK that sounds easy so how many RPM should be full advance ?
Steve - 72  BS23  FY1  'Cuda.
Melbourne, Australia.
The term "Foolproof", seriously underestimates the ingenuity of fools.
CUDA Crop by steve, on Flickr
Offline crash340
« Reply #17 on: March 16, 2015 - 03:16:55 AM »
Approx 3000rpm
Greg
73 Cuda
Brisbane, Australia
Offline Priesty
« Reply #18 on: March 20, 2015 - 06:48:27 AM »
OK, found some time today to have a play with the timing, set at 12* initial & around 34* total. Just curious, should the idle speed increase when I reconnect the vac advance after timing, & does this mean I have vac advance already at idle ?
Also removed thermostat housing for a look & lo & behold, no thermostat fitted. I'm thinking my warmer temp at highway speed is possibly because the coolant was flowing too quickly through the radiator. Bought a hi-volume 170* t/stat, & flushed & replaced all the coolant. Going on a cruise on Sunday, so fingers crossed, will see how it goes.
« Reply #19 on: March 20, 2015 - 11:58:23 AM »
Running without the  thermostat can definatly cause overheating so it seems you found the problem .
 I would leave the vacuum disconnected , if it increases speed connecting it you either have it connected to manifold vacuum which is incorrect or your ported vacuum source has vacuum at idle which it shouldn't , generally the engine will run better & be more responsive with improved power & milage with the timing increased as you have done , adding vacuum advance is not going to help as it will over advance now , so either wind the screw inside the vacuum pot all the way CCW or disconnect the hose so it cannot advance .
Offline crash340
« Reply #20 on: March 20, 2015 - 06:07:16 PM »
Thats good news Steve, I just did what CP recommends, wound the VA pot screw all the way CCW until it started clicking/jumping the thread. and blocked off my vacum. Car runs great.
Greg
73 Cuda
Brisbane, Australia
Offline Priesty
« Reply #21 on: March 20, 2015 - 06:32:20 PM »
Thanks guys , will do the same.
cheers.....
Offline Priesty
« Reply #22 on: March 30, 2015 - 11:46:43 PM »
Just a update on above. Car cruised at 190*f max all day with new t/stat & much more responsive now with tweaked timing & blocked off vac advance. Thanks all for your advice.
cheers..
Offline crash340
« Reply #23 on: March 31, 2015 - 05:03:20 AM »
 :bananasmi :thumbsup: :cheers:
Greg
73 Cuda
Brisbane, Australia
