So I take it from your responses that either size radiator could be factory fitted for my application ? Rad support opening is for 22".
Haven't had any boiling issues as such, but definitely running warmer than I'd like. I've had it out a few times recently where ambient temps were only around 25*c
(85*F app.), & the temp worked it's way up to around 210-215f. probably ok at that temp, but given that temps here can reach 35-43*c in summer (*96-120*f) I'm concerned that engine temp would rise accordingly. I already added a home fabbed fan shroud & swapped out the 13lb rad cap for a 16lb, but seems to have made little difference. Did seem to run slightly higher temp at highway speed (around 3200rpm) & backed down about 5*f when I exited highway, but still a little too warm for me.
OK, Q&A time:
Unsure of t/stat, will check out shortly.
40,000 fresh motor, stock bore & pistons, Direct 6 blade flexible fan (no clutch) approx. 1 1/2" from rad. face.
Yet to check timing. Around 12-16 btdc initial advance sound right ?
Aftermarket gauge used, might seek a second opinion from my trusty BBQ meat thermometer. Don't laugh, it's the most reliable temp gauge I've ever used.
Radiator is supposed to be freshly re-cored before I bought the car & does appear to be in reasonable condition with a recently date stamped tag. (2 row 22").
cheers....appreciate your input.
