Author Topic: What is Stock AAR Cuda Front Ride Height?  (Read 2696 times)
Offline lphfh
« on: March 10, 2015 - 11:08:52 PM »
Does anyone know what the stock front ride height measurement is for a stock AAR.  Either to the Ball Joint/TB Socket or Fender Lip
Offline anlauto
Re: What is Stock AAR Cuda Front Ride Height?
« Reply #1 on: March 11, 2015 - 07:15:28 AM »
I would guess it's the same as any other Cuda :dunno:
« Reply #2 on: March 11, 2015 - 10:37:04 AM »
It's my understanding that the front end height was the same as any other Barracuda.  The rear end height was higher on the T/A and AAR.
« Reply #3 on: March 11, 2015 - 11:09:17 AM »
1.125" IIRC, measured at the t-bar socket, which is higher than the lower ball joint.
« Reply #4 on: March 11, 2015 - 02:06:45 PM »
it should be around 24" at the fender lip & should be lower than a stock Cuda as the tire size was E60 not F 60
Offline anlauto
« Reply #5 on: March 11, 2015 - 03:06:35 PM »
The stock 15" tire size on ALL non-Hemi E Bodies was E60X15 NOT F60, in fact F60's were not available on any E Body without a Hemi :2cents:
Offline lphfh
« Reply #6 on: March 12, 2015 - 11:18:34 PM »
Thanks for the info
Offline whitewatersky
« Reply #7 on: March 18, 2015 - 10:50:51 PM »
thanks for the front height
would it be the Same for T/A ?
and what would the rear be ?
 :cheers:
Plum Crazy auto T/A Challenger
« Reply #8 on: March 19, 2015 - 10:25:01 AM »
No spec for the rear, at least from the service perspective. There is a factory number, but I've only ever seen one document with that info and it was never put in the Field Service Manuals.
The variability in tire diameters is why the factory never specified a ride height at a particular body panel but instead referenced it off suspension components, whose spatial relationship doesn't change with alternate tire sizes.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #9 on: March 19, 2015 - 11:44:51 AM »
The OE rear tire size was G60-15.  The only car to roll off the line with two different tire sizes (E60 in front and G60 in rear).
« Reply #10 on: March 20, 2015 - 07:12:31 PM »
Thanks guys. That's another thing I gotta organise. Some good tires
Offline anlauto
« Reply #11 on: March 20, 2015 - 07:23:50 PM »
AAR's and T/A's use different rear shock plates then all other 70 E Bodies to accommodate for the extra height in the rear :2cents:
« Reply #12 on: March 20, 2015 - 07:42:57 PM »
Thanks Alan. Onto the rear next week. Dang. Gotta get some new shocks!
