Author Topic: Cuda rear seat install  (Read 1728 times)
Offline twalker
« on: March 11, 2015 - 10:52:02 PM »
Anyone got pics of how the back of the rear seat mounts to the brackets on the floor?
Offline 67vertman
  • Member since 9-23-2005
Re: Cuda rear seat install
« Reply #1 on: March 12, 2015 - 12:11:36 AM »
No pictures, which seat do you need to know how to mount, the seat back or bottom?
Seat back, there are two brackets welded to the floor pan were is slopes up and there are two screw holes (one per side) there are two U shaped hooks on the seat frame, those bolt to the brackets. The seat can only go in one way.
Seat bottom, there are two brackets on the floor pan, one per side, that have a slot that the seat frame bottom slide into, you need to force it a little to get it to catch.
Offline Racer57
« Reply #2 on: March 12, 2015 - 08:34:26 AM »
Back of seat slides down over hooks then two screws are used to fasten bottom to brackets. Then you slide the bottom into place holding front up enough to clear the hooks so that it gets hooked into place. You might need to use your knee. :D
Offline TelisSE440
« Reply #3 on: March 14, 2015 - 09:58:57 PM »
Nicely said, my knee was the tool to install the bottom seat too!
