Author Topic: Changing out rear leaf springs on my e body: Tips?  (Read 1483 times)
Offline DocMel
« on: March 13, 2015 - 10:25:51 AM »
Any removal/installation tips out there?
Offline bigblue73
Re: Changing out rear leaf springs on my e body: Tips?
« Reply #2 on: March 17, 2015 - 11:14:12 AM »
Shoot all the nuts with penetrating oil.  Get an impact gun for the bolts on the leaf springs.  It's really straight forward once you get into it.  Allow about 6-8 hours to complete everything.  One thing to consider.....I bought all new stuff from the front spring hangers (AR Engineering) and rear hangers (Hotchkis) because I knew I would break bolts off the front spring hangers.
Have fun!
Offline Mpdlawdog
« Reply #3 on: March 17, 2015 - 03:46:15 PM »
 :popcorn:
Offline roadman5312
« Reply #4 on: March 17, 2015 - 04:07:13 PM »
Have fun!
                               :iagree: I also wire brush the threads on the U bolts before taking the nuts off. Fine threads don't like dirt, undercoat, paint etc.   :nono:
Offline dakota
« Reply #5 on: March 17, 2015 - 08:23:00 PM »
the fine thread on u bolts will foul up very easily.  After several attempts to loosen the nuts with an impact, I find it faster to cut the U bolts with a cutoff wheel and install new ones.
Offline jimynick
« Reply #6 on: March 17, 2015 - 11:17:21 PM »
OR, just heat the cleaned off nuts yellow hot with a torch and spin them right off with an impact and NOT shear the bolts off. I also used a broken off chisel ground flat in my air panel cutter to hammer the rear shackles/bolts since they get tighter than a bull's arse in fly time, as the old man used to say. Good luck  :cheers:
« Reply #7 on: March 18, 2015 - 02:32:37 PM »
If its never been apart, I'll try hitting it with penetrator every day for a week or more.  Try to chase threads where possible.
