Author Topic: Part ID and where to find?  (Read 5957 times)
Offline carcrazyguy
« on: March 13, 2015 - 09:33:24 PM »
Pretty sure it is an exhaust hanger?   It is welded to the floor hump (just in front of the rear axle).  Would there have been another on the other side if the car was a factory dual exhaust car?   Also there is a plate the bolts inside the trunk pan (possibly a muffler hanger bracket)?   I plan to go with dual exhaust so I need to find where to purchase these.
« Last Edit: March 13, 2015 - 09:59:57 PM by carcrazyguy »
Offline carcrazyguy
Re: Part ID and where to find?
« Reply #1 on: March 13, 2015 - 09:37:25 PM »
I don't have a pic of the bracket from inside the trunk.  :banghead:  Here is the bottom side...
EDIT: I think I found these... :2thumbs:
http://www.dalescudashop.com/197074-ebody-muffler-h197074.html
« Last Edit: March 13, 2015 - 10:29:57 PM by carcrazyguy »
« Reply #2 on: March 13, 2015 - 10:26:03 PM »
That part circled is the brake line bracket bolts onto and T's so it sends a line over the Diff.
The Exhaust brackets are bigger
Offline carcrazyguy
« Reply #3 on: March 13, 2015 - 10:33:21 PM »
Thanks.  :thumbsup:
So where are the floor pan brackets for the dual exhaust?  :clueless:   My car was a single exhaust car but I don't see the floor pan brackets...or I am blind.  :bigshades:
« Reply #4 on: March 13, 2015 - 10:59:56 PM »
There's divits on the underside...that's where you drill out for the exhaust bracket.
Offline anlauto
« Reply #5 on: March 13, 2015 - 11:01:43 PM »
What year is your car ?
« Reply #7 on: March 13, 2015 - 11:15:40 PM »
Offline carcrazyguy
« Reply #8 on: March 13, 2015 - 11:26:53 PM »
This is a 73 Barracuda.
« Reply #9 on: March 13, 2015 - 11:39:59 PM »
It won't be any different than my picture.   :2cents:
I can even see the indented area for the bracket in your picture.
« Reply #10 on: March 14, 2015 - 05:58:42 AM »
Your first picture is of rear seat belt anchor nuts.. OE Hanger brackets are covered in these posts http://www.cuda-challenger.com/cc/index.php?topic=103032.0
http://www.cuda-challenger.com/cc/index.php?topic=102566.0
« Last Edit: March 14, 2015 - 06:00:35 AM by Bullitt- »
Offline anlauto
« Reply #11 on: March 14, 2015 - 08:02:03 AM »
73's don't have the bracket welded to the passenger side floor either. 73's use a bracket bolted to the shock cross member. :2cents:
Offline FY1Cuda
« Reply #12 on: March 14, 2015 - 12:12:43 PM »
I think that little bracket holds the E-brake cable up that runs over to the passenger side wheel.  There should be a little ring on that cable that screws into that bracket.
Offline anlauto
« Reply #13 on: March 14, 2015 - 12:39:13 PM »
Only in 1970 was the E Bake cable secured to the body in that location.
In 1971-74 that little welded on bracket supports the brake flex line bracket.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #14 on: March 14, 2015 - 06:08:34 PM »
Didn't the 70's exhaust brackets have these welded to the underside and not bolted?
« Last Edit: March 14, 2015 - 06:10:20 PM by HP_Cuda »
