Author Topic: Inner Fender Splash Shields  (Read 2058 times)
Offline Recovering Cuda
« on: March 14, 2015 - 01:47:01 PM »
Greetings Gents,  just a quick question on a 1973 'Cuda.  I have acquired some repro inner front fender splash shields.  These are the heavy rubber "flaps" that cover the holes in the lower front fender behind the shock tower, just above the frame rail.  My question is are they attached from the wheel wheel well area or from the engine bay area?   It appears that it should be mounted from inside the fender well as that area is flat and receives the shield better than the inside.   PO removed them so I want to make sure.
Thanks.
Offline anlauto
Re: Inner Fender Splash Shields
« Reply #1 on: March 14, 2015 - 02:16:02 PM »
Both....
The driver's side mounts on the wheel side of the inner apron and the passenger side mounts on the engine side of the inner apron :2cents:
« Reply #2 on: March 14, 2015 - 10:00:51 PM »
Thanks Alan,  I would have never guessed that one side was reversed.    Have a good one.
Offline daveh
« Reply #3 on: March 15, 2015 - 10:37:34 AM »
Does anyone have any pictures illustrating of how they are mounted?
Offline Giveitawack
    • ebay
« Reply #4 on: March 15, 2015 - 12:19:31 PM »
Aren't both sides mounted from the wheel side?
Offline crash340
« Reply #5 on: March 15, 2015 - 04:10:53 PM »
Here you go, this is of my 73 Cuda, showing right side on the inside fitted, and left side in wheel side, I had removed it but you can see where it was
Greg
73 Cuda
Brisbane, Australia
Offline roadman5312
« Reply #6 on: March 15, 2015 - 04:18:20 PM »
Both....
                    Any idea what the thinking/engineering logic was ?   :clueless:
Offline crash340
« Reply #7 on: March 15, 2015 - 04:26:15 PM »
 :dunno:
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
« Reply #8 on: March 15, 2015 - 05:06:28 PM »
Maybe the installer was standing on the left side of the car as it went down the line... :smilielol:
Offline crash340
« Reply #9 on: March 15, 2015 - 06:18:31 PM »
That's about what I was thinking as well
Greg
73 Cuda
Brisbane, Australia
