Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Harmonic balancer loose
« previous
next »
Print
Pages: [
1
Author
Topic: Harmonic balancer loose (Read 972 times)
leanburn
Full Member
on:
March 15, 2015 - 11:35:00 PM »
I fired my car up today, it has been sitting for 5 months, long story short I could move the outer part of my harmonic balancer about 5 degrees until it warmed up. Now it seems fine. Am I dillusional to think there's something wrong ?
Logged
burdar
Sr. Resident
Re: Harmonic balancer loose
Reply #1 on:
March 16, 2015 - 04:56:13 PM »
If you can move the outer ring separately from the center, then the rubber between the two parts has deteriorated. You need a new balancer. If the outer ring slips, your timing mark is now "off".
Logged
BIGSHCLUNK
Sr. Resident
Miss NIKKI - were you this hot at 48?
Reply #2 on:
March 16, 2015 - 05:16:55 PM »
Agreed and if you run it, its a time bomb waiting to go off! I'd swap it out quick
Logged
[o o o o]
OO
OO
[o o o o]
leanburn
Full Member
Reply #3 on:
March 16, 2015 - 10:20:20 PM »
That's what I thought. Just needed to check in case I was missing something Thanks
Logged
jimynick
Resident
Reply #4 on:
March 16, 2015 - 10:22:58 PM »
Quote from: BIGSHCLUNK on March 16, 2015 - 05:16:55 PM
Especially if it's an externally balanced engine. They have an eccentric weight that needs to be in it's right place and sliding around on the hub -isn't it. THEN, there's the issue of where that nice big piece of steel goes if and when it comes off the hub. Think about it for a minute.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
March 21, 2015 - 09:31:25 PM »
Are you sure it was just the outer ring slipping , often the crank will move 4-5* easily before the timing chain tightens up the slack & starts turning the cam oil pump dist etc .
if it is the outer ring I agree with everyone else replace it now
Logged
leanburn
Full Member
Reply #6 on:
March 24, 2015 - 09:16:50 PM »
Yes, definately the outer ring
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
