Author Topic: Power Steering Pump Cap  (Read 3558 times)
Offline marc70challenger
« on: March 18, 2015 - 12:24:34 PM »
Long > short.  I notice small amounts of power steering fluid on the casing.  The cap leaks.  When you put it on and give it proper turn .. you can pull it right off with just little pressure.
From the look of it ... I am not even sure it is right cap (tabs are much smaller than slots in neck of pump) .... and after calling around to summit, yearone, and some others ... I know why they may not have the right one on it .... I can't seem to find anyone that sells cap.
I fabricated a rubber gasket (one on cap seems to thin or small) ... that seems to keep cap on with more vigor ... but ....
Anyone have any suggestions?  Or am I just looking in wrong places?
Thanks for the help!
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Re: Power Steering Pump Cap
« Reply #1 on: March 18, 2015 - 12:34:24 PM »
What ps pump do you have? Federal or Saginaw?  They probably take a different cap.
« Reply #2 on: March 18, 2015 - 12:56:45 PM »
I'm not sure.   :dunno:
Here's a quick pic I took.  Not sure if anyone can tell from this shot or angle.
But you may be right - it might have cap from other brand.
Thx!
« Reply #3 on: March 18, 2015 - 01:00:41 PM »
That's a Saginaw pump and the cap looks correct.  It's just plastic and could be warped.  I just Googled "Saginaw ps cap" and came up with this.  It's probably available from many other sources. Try Dave at Roseville and see if he can get one.
http://www.classicindustries.com/product/mopar/parts/c82581.html
« Reply #4 on: March 18, 2015 - 01:04:04 PM »
Thank you very much!!!
If you're every in Northern Virginia - I owe you a beer or two ...  :thumbsup:
Offline jhaag
« Reply #5 on: March 18, 2015 - 01:35:42 PM »
drive down to your local auto parts store and look on their "Help" rack. Any good store will have several in stock.
love 70 Challengers
Offline 4 speed fish
« Reply #6 on: March 18, 2015 - 05:15:53 PM »
The caps are sold on ebay.
Offline anlauto
« Reply #7 on: March 18, 2015 - 05:46:21 PM »
 :iagree: Pretty common part, I would try NAPA or something before going to a restoration shop. :2cents:
« Reply #8 on: March 18, 2015 - 09:42:46 PM »
yep... same cap as the standard gm cap too I believe.
« Reply #9 on: March 19, 2015 - 08:31:41 AM »
Thanks everyone!!   You guys (and gals) are so helpful and kind   :thumbsup:
Since weather has been icky, I've had time to really go over the car ... the resto they did seems excellent .... just a few minor things here and there I've trying to get nailed down before we start running her ..  :burnout:
« Reply #10 on: May 22, 2016 - 06:31:45 PM »
Just confirming that pic shows Saginaw pump?
Offline 73440
« Reply #11 on: May 22, 2016 - 11:03:15 PM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline bc3j
« Reply #12 on: May 23, 2016 - 03:49:32 PM »
The Saginaw OEM caps had ears on them. The replacements are like the picture. My OEM developed a leak and a thin rubber gasket solved the problem.
« Last Edit: May 23, 2016 - 03:51:27 PM by bc3j »
« Reply #13 on: May 23, 2016 - 04:23:10 PM »
My 73 has the style that's pictured.  They must have changed them at some point.
