Author Topic: 1973 cuda Break vacuum assist  (Read 1569 times)
Offline cuda lover
« on: March 20, 2015 - 12:54:04 AM »
I think the vacuum assist is not holding vacuum and would like to replace it. I did the one on my '73 challenger not too long ago. I thought they would be the same part number. but searching on line they come up as different units.
Can I use the same unit?
CUDA Lover
Re: 1973 cuda Break vacuum assist
« Reply #1 on: March 20, 2015 - 12:06:58 PM »
I am not sure why they would be different but either should interchange , I think they used 2 different makes in different years such as Bendix
 If you shut off the engine & remove the hose you should be able to rock the check valve & hear the air sucked in if it is holding vacuum , also if the engine is running & you remove the hose & plug it & the engine runs differently / better with the hose plugged then the booster is leaking , this can cause a misfire on the cylinder where the vacuum port is connected as it will run lean with the extra air pulled into that port .
Offline cuda lover
« Reply #2 on: March 20, 2015 - 01:45:47 PM »
Thanks for the info,
My neighbor heard a hissing is what is making us suspicous for a leak in the vacuum assist.
I have a vacuum pump, I can also check it by seeing if it holds vacuum.
thanks again.
CUDA Lover
Offline cuda lover
« Reply #3 on: April 07, 2015 - 11:13:08 AM »
here is the vaccumn brake assist and new master cylinder installed
CUDA Lover
Offline twalker
« Reply #4 on: April 07, 2015 - 01:20:34 PM »
Where did you buy yours?  Like the look of it
Offline cuda lover
« Last Edit: April 07, 2015 - 02:22:45 PM by cuda lover »
CUDA Lover
« Reply #6 on: April 08, 2015 - 01:05:24 PM »
So that fixed the problem ?
Offline cuda lover
« Reply #7 on: April 08, 2015 - 04:42:11 PM »
Haven't tested it yet. I ran out of daylight that day , have to bleed breaks. will let you know.
Should have time Friday afternoon.
CUDA Lover
