Author Topic: Door Glass Up-Stop 70 Challenger  (Read 1210 times)
Offline LAA66
« on: March 21, 2015 - 12:40:07 PM »
 The bumper/block on the door glass up-stop has finally given out and I haven't been able to find a replacement. Has anyone here  made a custom replacement for their car? I think it is a solid triangular piece of rubber but not sure if it holds the glass laterally or is just a limit stop.
Offline moparcardave
Re: Door Glass Up-Stop 70 Challenger
« Reply #1 on: March 21, 2015 - 08:19:39 PM »
http://www.ebay.com/itm/like/371207944719 :wavingflag:
This is only what I am aware of, might be the bottom on, not sure.
Offline tman
Offline LAA66
« Reply #3 on: March 24, 2015 - 12:24:01 PM »
Thanks for the link, it looks similar but on a 70 it has notches on one end to fit a rubber bumper. Guess I'll take apart the other door and try to match whats there.
Offline LAA66
« Reply #4 on: May 11, 2015 - 03:23:11 PM »
 This up-stop bracket is from the passenger side and looks to be the original. It has a glass stabilizing/retaining function (according to the wear pattern) along with the up stop limit. I need to now make up a felt block for the driver side as without it the metal will scratch the glass when operating the window.
Offline whitewatersky
« Reply #5 on: May 12, 2015 - 08:50:39 AM »
Intersting
Plum Crazy auto T/A Challenger
« Reply #6 on: May 12, 2015 - 09:11:21 AM »
This looks similar, NOT listed for 70 Challenger...Compare the measurements
 http://www.steelerubber.com/glass-up-stop-bumper-70-3623-62
I've read they will consider reproducing if supplied with a good original.
Offline LAA66
« Reply #7 on: May 12, 2015 - 12:25:17 PM »
 Measurements are the same. Thanks!
