Author Topic: Quarter Seam  (Read 2178 times)
Offline glovemeister
Quarter Seam
« on: March 22, 2015 - 04:06:10 AM »
Planning ahead for dealing with the quarter seams. Thus far the current plan is to carefully weld them solid, grind down the welds a bit. Hit the seam with weld through primer  then install/weld flat steel in the channel.
Does that sound good, or should I skip the weld through?
1971 Challenger RT
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
Re: Quarter Seam
« Reply #1 on: March 22, 2015 - 10:42:23 AM »
You will need the primer to help reduce rusting.
E-Body Products
www.ebodyproducts.com
606-481-9014
Re: Quarter Seam
« Reply #2 on: March 22, 2015 - 02:49:02 PM »
E-Body Products
606-481-9014
Thats what I was kind of thinking. Rather try to "overdo" everything than have trouble later because I wasn't doing everything I should.
1971 Challenger RT
Offline jimynick
Re: Quarter Seam
« Reply #3 on: March 22, 2015 - 09:47:42 PM »
Why not just solder them in like the factory did?  :dunno:
Re: Quarter Seam
« Reply #4 on: March 23, 2015 - 02:49:34 AM »
I'm familiar with welding. I have all the tooling/chemicals on hand to perform it, and likely get satisfactory results.
Soldering is fine, but the time/money spent to learn it can be better suited elsewhere. From all the research I can see on this forum, as well as across other forums, a properly welded/filled c pillar/quarter seam is a good way to go.
1971 Challenger RT
Offline AARTA340
Re: Quarter Seam
« Reply #5 on: March 23, 2015 - 08:41:47 AM »
Off the line back in the day, the factory spot welded the quarter to the roof. Then on cars with a vinyl roof they used filler/bondo. On cars with painted roofs, they used lead/solder as it would not shrink and thus show a crack. If the filler cracked with the vinyl, it would not show unless the vinyl was replaced.  :2cents:
Re: Quarter Seam
« Reply #6 on: March 23, 2015 - 10:05:29 AM »
If you were to butt weld a section in from roof to quarter panel, it'll be more work and time than if you were to just lead/solder. A patch over the gap I would not recommend.   :2cents:
About 150-250 dollars to have lead DIY products.
Offline jimynick
Re: Quarter Seam
« Reply #7 on: March 23, 2015 - 08:56:37 PM »
As always, it's your car and your choice.  :thumbsup: A couple of things though- my 74, factory vinyl roofed car had soldered 1/4 seams and I should know, since I'm the guy who melted them out. As for soldering, may I suggest an hour or two on YouTube and I think you'll see that it's not too hard to do. The beauty of it is that you can file off everything that doesn't look like a 1/4 panel and the only real tool you need are a wooden paddle- that you could make yourself if you're handy that way and a metal body file and handle. Hope it works out for you no matter which way you go.  :cheers:
Re: Quarter Seam
« Reply #8 on: March 23, 2015 - 10:22:28 PM »
If you're familiar with welding then Leadwork should be easily adaptable for you. You understand heat.
About 1-2 hours max per side.
Solder/Leadwork is not overkill, costly, or that hard to learn.
Were you good with making campfires like a Boyscout ever? If you're good with fire, then you can adapt easily.
It's all about finding that melting point of the solder bar. Benz O Matic makes the ideal propane torch for doing leadwork. http://www.bernzomatic.com/item.html?id=9
Eastwood sells the thin bars that are really easy to work with.
