Author Topic: World Map  (Read 1299 times)
World Map
« on: March 22, 2015 - 07:41:37 AM »
I saw this over on the FT86 forum that I'm a member of. Thought it was a cool way of seeing where everybody is from.
https://www.zeemaps.com
Maybe we could set one up as a sticky under cudas and challengers galore? or?
Appears to be free.
It is fairly simple to add markers. Here are the instructions from FT86. Sub in Cuda/Challenger for FRS/BRZ and you are good to go.
INSTRUCTION FOR ADDING A MARKER TO THE MAP
- On the upper left tabs, select "Add Marker - Simple." An "Add Entry" box will appear.
- Enter information in the "Entry Name" field such as the model year of your FRS/BRZ, color, trim level, and coupe or convertible. You can also select the color of your marker here, allowing you to make your marker the color of your FRS/BRZ.
- Then either enter a specific location (City and State) or zoom to the location that you want to mark on the map.
- If you entered information in the "Location" field, click the "Preview" button to make sure the marker is where you want it. If it is, click the "Submit" button.
- If you zoom to the specific location that you want to mark, click on the "Click on a map location" hyperlink. A "Click on map to select location will appear. Click "OK" and then single click on your location and a marker will appear. Finally, click the "Submit" button to post your marker.
Offline MirageCuda
  • 1974 Cuda
Re: World Map
« Reply #1 on: March 22, 2015 - 11:22:00 PM »
Pretty cool idea.
Randy
1974 Plymouth Cuda
2006 Dodge Ram 1500 SLT
1991 Nissan Skyline GTR
2002 Subaru Impreza WRX
