Author Topic: "Hidden" Engine Bay Wiring - Your Methods  (Read 13385 times)
Offline 70chall440
Re: "Hidden" Engine Bay Wiring - Your Methods
« Reply #30 on: February 29, 2016 - 01:46:31 PM »
I have always run my cables through the interior on the drivers side under the wiring plate. If it cannot be safe there, it will not be safe anywhere else IMO. You just have to make sure it is protected (regardless of where you run it).
Current Mopar
Past Mopars
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #31 on: February 29, 2016 - 02:57:41 PM »
A wiring plate would is a must if going through the interior, good call!   :2thumbs:
Offline 70chall440
« Reply #32 on: February 29, 2016 - 03:37:55 PM »
 :iagree: always use them. I also ensure there is some type of locating/holding devices used to keep the cable exactly where I want it to be. Anything that poses even a remote chance of cutting or rubbing the cable is padded or the cable is protected. A little attention to detail here is worth a lot.
Current Mopar
Past Mopars
Offline dave73chally
« Reply #33 on: February 29, 2016 - 03:59:46 PM »
Is there a wiring plate under the carpet or do I need to buy one?
73 Challenger
Offline dfrazz
« Reply #34 on: February 29, 2016 - 04:02:18 PM »
There is only a "channel" to hold the wiring under the sill plate.  I would go buy a wiring plate for your battery cables.
Offline 70chall440
« Reply #35 on: February 29, 2016 - 04:07:12 PM »
on the left side of the car (beside the seat at floor level, under the carpet) there is a sheet metal plate which protects wires running from front to back. They are spot welded to the floor on tabs. The plate can be bent out to gain access to the wiring, however on some cars, the tabs can break, however most of the time they are fine and can be used for years. You can also make one if yours is gone or you want something different.
Current Mopar
Past Mopars
Offline YellowThumper
  • I left the snow for this?
« Reply #36 on: February 29, 2016 - 04:25:06 PM »
It is a simple plate and an additional one could be added for the passenger side interior sill.
FWIW I am using a relay block scrounged from a Lincoln that had a trunk mount battery. It's main power line is inside the cabin.
Offline Georgewaw
"Hidden" Engine Bay Wiring Your Methods
« Reply #37 on: March 31, 2016 - 05:36:08 AM »
ok so i guess the engine bay cover is outa the question. what engine components are paintable...? i know the valve cover, but what else?
« Reply #38 on: March 31, 2016 - 09:25:40 AM »
Everything is paintable. Whether it lasts or can be done in a manner that looks good is the question. If you really want an engine cover, I don't see why you couldn't adapt or fabricate one up.
Offline 70chall440
« Reply #39 on: March 31, 2016 - 10:02:40 AM »
I am sure you could fabricate one, but why would you? On new cars it is one thing, but on a vintage car I think it would be distracting.
Current Mopar
Past Mopars
« Reply #40 on: March 31, 2016 - 03:08:52 PM »
 :clueless: ...hiding the entire engine bay?  :lol:
73 Challenger
Offline 70chall440
« Reply #41 on: March 31, 2016 - 03:42:02 PM »
I think it is a trend to a degree. A lot of the custom car builders do this as a matter of course.
Current Mopar
Past Mopars
