Author Topic: Compression Test  (Read 5243 times)
Offline Dusty1
  • Revived
Compression Test
« on: March 24, 2015 - 08:04:04 PM »
After a year of getting the bugs out of my 340, I got brave enough to do a compression test. I guess the results explain a few of the issues I had. I was told a '68 340 would run about 120 lbs. , is this correct? So is 155 lbs. too much?
Garys 1972 BS
Re: Compression Test
« Reply #1 on: March 24, 2015 - 08:55:39 PM »
No , that is what I would expect to see
Offline Dusty1
  • Revived
« Reply #2 on: March 24, 2015 - 09:13:29 PM »
155 is normal pressure? I really didn't know what it would have. Thanks
Garys 1972 BS
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: March 25, 2015 - 12:05:41 AM »
My 120,000 mile 318 had 135 to 140 psi, so 155 is good.
Offline Dusty1
  • Revived
« Reply #4 on: March 25, 2015 - 12:11:30 AM »
Thanks Ron
Garys 1972 BS
Offline cudabob496
« Reply #5 on: March 25, 2015 - 04:57:17 AM »
where are you in so Cal?
2011 Kawasaki Z1000
Offline AussieMark
« Reply #6 on: March 25, 2015 - 06:47:29 AM »
Did you do the test with a warm engine, all spark plugs removed and gas pedal fully pressed down? I would expect between 160 and 180 this engine was a high compression, premium fuel engine and should actually have the same test results as a street Hemi. The main thing to look for is equal pressures from each cylinder with only small differences.
« Last Edit: March 25, 2015 - 06:51:18 AM by AussieMark »
Offline blown motor
« Reply #7 on: March 25, 2015 - 08:38:31 AM »
5000 miles after the rebuild my 340 tested one cylinder at 148 and the rest at 155.
Offline Dusty1
  • Revived
« Reply #8 on: March 25, 2015 - 11:30:00 PM »
Cold motor, all other plugs in and didn't touch the gas, just cranked it. It didn't very 5 lbs. on every cylinder. Sounds like I needed a little more instruction!
Garys 1972 BS
Offline DocMel
« Reply #9 on: March 26, 2015 - 09:54:07 AM »
I really dont focus on what one or two readings might give me.  I take the old school approach, take all 8 readings and ensure the highest and lowest reading does not differ more than 10%  But single reading on a suspect cylinder to diagnose a prob is not a bad idea
Offline AussieMark
« Reply #10 on: March 27, 2015 - 05:17:35 AM »
I really dont focus on what one or two readings might give me.  I take the old school approach, take all 8 readings and ensure the highest and lowest reading does not differ more than 10%  But single reading on a suspect cylinder to diagnose a prob is not a bad idea   Exactly the more equal the pressures are the better
Offline brasil
« Reply #11 on: April 03, 2015 - 05:35:27 PM »
mine showed 175 to 180 psi on all cylinders  when I checked the compression last year....
Greetings Jurgen
Offline 734406pk
  • Andy
« Reply #12 on: April 03, 2015 - 06:03:22 PM »
What kind of issues are you having?
Offline Dusty1
  • Revived
« Reply #13 on: April 06, 2015 - 09:48:23 PM »
After the rebuild, a couple of years ago, I would only get a couple of hundred miles on it before it would push the felpro head gasket out from under the left head. Put a cometic gasket on it and it started blowing water out under the header toward the front of the left head. After a lot of consultation on this site, I put new ARP bolts in and used copper spray sealant on the new cometic gasket. 1000 miles and no problems yet. Just now able to get to things like this instead of tearing things back apart.
Garys 1972 BS
Offline 734406pk
  • Andy
« Reply #14 on: April 07, 2015 - 03:11:26 PM »
 That's strange, only the left cylinder head. Are these aluminum heads? Hopefully it will now stay sealed with the ARP bolts and Cometic gaskets. Best of luck!
