Author Topic: Compression Test  (Read 5241 times)
Offline Dusty1
  • Revived
Re: Compression Test
« Reply #15 on: April 07, 2015 - 07:47:06 PM »
The right would push some but never come out from under the head. I was told by the ones who know, that the left will fail first. Iron X heads. I really hope they hold, I'm tired of working on the same problem over and over.
Garys 1972 BS
Offline 734406pk
  • Andy
« Reply #16 on: April 07, 2015 - 08:08:25 PM »
Having to constantly change head gaskets gets old fast. Assuming the heads and block are flat, it appears to me you have a clamping issue due to the stock head bolts stretching. You can see in the pic that cylinder pressure is pushing the gasket outward centered between 2 bolts. The ARP bolts and a premium head gaskets should solve your issue. Best of luck and post back your results!
Offline Dusty1
  • Revived
« Reply #17 on: April 07, 2015 - 08:37:31 PM »
Thanks! I hope the new bolts were the right answer. I'm thinking 40 year old bolts shouldn't be reused :thinkerg:
Garys 1972 BS
Offline 734406pk
  • Andy
« Reply #18 on: April 07, 2015 - 08:56:10 PM »
 Cheap insurance: ARP head bolts, main cap bolts and con rod studs. We live and learn. Good luck!
