Within a couple months I'll be starting the long needed restoration of my 70 challenger. Looks as if I will need to replace the rear cross member behind the rear bumper, both rear cross member corner pieces, Lt side trunk extension drop down, some clean up of the Lt rear frame rail and Lt side trunk patch or Lt half trunk replacement Also Lt outer wheel well and lower half of Lt quarter. How would you experienced body guys tackle this? Started out small but the restoration is growing. Found a lot of bondo in Lt rear quarter fwd and aft of wheel well. If half the trunk, rear cross member, drop down extension and lower half of quarter is cut off, will bracing of the back end be required. The Lt rear frame rail spot welds have pulled through the trunk floor. Sorry for the long novel.
