Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Differential lube
« previous
next »
Print
Pages: [
1
Author
Topic: Differential lube (Read 1050 times)
john h
Jr. Member
Differential lube
on:
March 27, 2015 - 08:25:26 PM »
has any one used hte Lucas diff lube with any results in quieting down noisy gears. It claims it can be used either as 50% mix or even 100% lube. it also says you would not need any other additives for limited slip setups. Also wondering about the Vavoline full synthetic 75-140? anyone used that with success in quieting down the Diff?
I'm Just trying to prolong the need to spend $1400 on a replacement.
Thanks
John
Logged
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
jimynick
Resident
Re: Differential lube
Reply #1 on:
March 27, 2015 - 10:02:59 PM »
John, if Lucas- or any other lube manufacturer for that matter, were able to cure the woes of a noisy diff with any certainty, the diff shops would be out of business. It's noisy for a reason- either a bearing or gear engagement problem being the most likely. This months CarCraft has an article on rebuilding a 8.75 SG Mopar diff and it sure didn't cost $1400. You might quieten it down a wee bit with a lube change, but leaving it go will only cost more in the (rear)end. Just my
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 28, 2015 - 12:04:27 AM »
most of what I have read do not recommend synthetic oil for diffs
What type of noise ?
Whine on accel or decel is usually gear mesh or all the time is brgs
Logged
Denison636
Jr. Member
Reply #3 on:
March 28, 2015 - 12:21:56 AM »
Think I did my 3rd member for under 500 and that was paying to have the gears set up for me.
Logged
Its just a little 340 with a miss
73440
Sr. Member
Reply #4 on:
March 28, 2015 - 02:50:27 AM »
I had a 65 Fury III that started doing a semi lockup at the rear end suddenly, I always use Lucas products , but as all have said that won't fix those problems there.
Logged
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
dodj
Sr. Resident
Reply #5 on:
March 28, 2015 - 09:24:03 AM »
Quote from: Chryco Psycho on March 28, 2015 - 12:04:27 AM
Really? How come? That's all I use in my Challenger, my truck, ....
Amzoil Severe Gear.
Logged
1973 Challenger 440 4 spd
john h
Jr. Member
Reply #6 on:
March 28, 2015 - 09:27:10 AM »
Thanks for the info guys. I appreciate getting straight no bull answers.
John
Logged
John
73 Cuda
360 Crate motor
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Differential lube
