Author Topic: Pinion Bearing Preload  (Read 548 times)
Offline 1 Wild R/T
« on: March 28, 2015 - 11:08:43 AM »
Just looking for opinions on setting up pinion bearing preload, I'm using a solid spacer not a crush sleeve & I don't have the "ideal" shim... With the thinnest shim bearing preload is about double the correct number at 45 in/lbs the next thicker shim is .004 thicker & drops the preload to about 6 in/lbs... which is about 1/3 the spec... I like to set them up a little on the tight side so 25-30 I'd run but 45 concerns me.... At this point I'm leaning toward leaving the preload at 6 in/lbs.... t I don't trust my skills or my worn out lathe to accurately cut the spacer without creating more runout which would do more harm than leaving the thing alone.... Any thoughts?
Offline 734406pk
  • Andy
Re: Pinion Bearing Preload
« Reply #1 on: March 28, 2015 - 11:35:13 AM »
Sometimes that's the problem with the solid spacers. They leave you hanging inbetween too tight and too loose. I would take the spacer to a machine shop and have them shave it off as necessary to get your correct preload. Setting up the rear axle  bearing preloads correctly is critical.
