Hey gang, just had a couple quick questions around T/A hoods.
About 15 years ago, we added the fiberglass T/A scoop to the steel hood of my 74 Challenger. Pic attached. It's worked SO GOOD for the last 15 years, but it's just starting to show signs of cracking around the edge She's due for paint next month, so I'm toying with the idea of replacing the entire hood with a fiberglass one from these guys, who I've heard good things about:
https://www.aarqualityfiberglass.com/products/hood-challenger-1970-1974-ta-bolt. So my questions are these:
1. Has anyone bought a hood from these guys and painted it? How were the results
2. Is there a better manufacturer I should be looking at?
3. Will the hood lip molding from a 74 bolt on to this hood so that it aligns with the fender moldings?
4. The disclaimer on Year One's T/A hood springs says "Recommended for show use only". Do you run em all the time? Are there other options?
5. I'm guessing that the hood hinge is the same, and only the spring is different, is that correct?
6. Anything else I should be thinking about?
Thanks a bunch!
