Author Topic: Scattershield Question  (Read 853 times)
Offline Longhorn1970
  • Newbie
« on: March 30, 2015 - 08:22:25 PM »
Has anyone installed a Quicktime scatter shield on an E-body? I am in the process of installing the shield, but the stock torque shaft ball stud doesn't fit on the bracket located on shield (the hole is too small). I don't want to drill out the bracket if there is another ball you can use. Additionally, if I had to drill out the bracket not sure which hole to enlarge. I called Quicktime and didn't get any good information. Also, I was curious if you can use the stock Z bar. I appreciate the help!
Offline anlauto
Re: Scattershield Question
« Reply #1 on: March 30, 2015 - 08:26:52 PM »
I've installed one, but can't answer any of your questions because I used a hydraulic clutch set-up...highly recommended :2thumbs:
Offline bigblue73
« Reply #2 on: April 06, 2015 - 03:59:19 PM »
Call into Quicktime, which was purchased by Lakewood about 4 years ago and see if you can talk to Ross.  Ross is the innovator and previous owner of Quicktime Brand.  It's sounds like you may be missing a bracket that bolts to a bracket (yes I said that) that allows you to use the original ball stud and z-bar arrangement.  Good luck and rest assured the Quicktime Bell Housing is a quality piece.
