Author Topic: 833 pictures  (Read 2767 times)
Offline Sleepychallenger
833 pictures
« on: March 31, 2015 - 02:39:40 PM »
does anyone have photos of how the shift levers should look on the transmission? I am having a horrible time with the 1-2 shift and it is driving me nuts. In 1st, if I get on it hard it will buck out of gear and pop back in. Second does not always grab, will occasionally grind when it does grab and sometimes grinds with the clutch in. Second is really finicky when it is going to grab but once it is in it drives just fine until the next time I have to shift to second. I do a lot of 1 - 3 shifting right now. Any ideas help. I know my mount is toast and will be getting replaced later tonight. But I don't know if I have the levers in the right spots.
Offline HP_Cuda
  • Mopar or No Car!
Re: 833 pictures
« Reply #1 on: March 31, 2015 - 07:25:56 PM »
You mean this?
Looking at it - its not in neutral
Offline CudamanTom
Re: 833 pictures
« Reply #2 on: March 31, 2015 - 08:38:22 PM »
Mine is in neutral.
« Last Edit: March 31, 2015 - 08:40:00 PM by CudamanTom »
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Re: 833 pictures
« Reply #3 on: April 01, 2015 - 05:40:48 PM »
yup. that's what I was looking for. Im pretty sure that part of my problem is not having the right shift levers in there. thanks to both of you.
Offline 67vertman
  • Member since 9-23-2005
Re: 833 pictures
« Reply #4 on: April 01, 2015 - 11:22:50 PM »
What type of A833 do you have? standard or overdrive? it make a difference on how the levers should be pointed.
here is a good thread on an overdrive setup. http://www.cuda-challenger.com/cc/index.php?topic=86395.msg933269#msg933269
Re: 833 pictures
« Reply #5 on: April 02, 2015 - 11:00:19 AM »
its a SB trans out of a 73 cuda
Offline HP_Cuda
  • Mopar or No Car!
Re: 833 pictures
« Reply #6 on: April 02, 2015 - 07:32:48 PM »
Mine is cleaner!!!
:P
Offline CudamanTom
Re: 833 pictures
« Reply #7 on: April 02, 2015 - 08:16:21 PM »
Mine is cleaner!!!
:P
 :smilielol: Mine was closer to the camera.  :P :poopoke:
Plus, yours was in gear and not even a blur.  :roflsmiley:
« Last Edit: April 02, 2015 - 08:18:05 PM by CudamanTom »
Offline HP_Cuda
  • Mopar or No Car!
Re: 833 pictures
« Reply #8 on: April 02, 2015 - 09:21:54 PM »
Mine was supported by jack stands!!!
 :woohoo: :smilielol:
Offline CudamanTom
Re: 833 pictures
« Reply #9 on: April 02, 2015 - 09:34:38 PM »
Mine was supported by one heavy duty dolly and high performance casters with high speed aircraft grease. :wave:
 :bigsmile:
So comparing both pictures, mine will move faster with less drag when moving it swiftly across the shop.  :P
Edit: tailored down the details a bit.
« Last Edit: April 02, 2015 - 10:00:50 PM by CudamanTom »
