Author Topic: Clutch style sure grip ring gear bolts ?  (Read 638 times)
Offline joelson6
« on: April 02, 2015 - 06:43:21 PM »
i have a Richmond 3.73 setup for my 489 housing. last year i sheared off all 12 ring gear bolts on a 1-2 shift. that's another story.
the ring and pinion are ok, so i pull my clutch sure grip from the 3.73's and put it in a set of 4.10's i have. i found another clutch
sure grip to put the 3.73's back together. rebuilt the unit with new clutches and bearings. went to bolt the ring gear on with new
ARP bolts and the shoulder on the bolts get's hung up on the hole in the sure grip. the shoulder of the bolt is too big for the hole.
has anyone else come across this? what did you do to solve the problem? thanks, Greg
Offline Bart
Re: Clutch style sure grip ring gear bolts ?
« Reply #1 on: April 06, 2015 - 10:18:33 AM »
Yep had to drill out to next size bigger.
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
