Author Topic: UCA Ball Joint Issues  (Read 12086 times)
Re: UCA Ball Joint Issues
« Reply #15 on: April 06, 2015 - 09:17:13 PM »
Ok I'll bite where is it loose , is the ball joint loose in the control arm or is the ball joint pin loose in the ball joint housing ??
The ball joint pin is loose inside the ball joint housing itself.
Wore out way too fast. I pumped quite a bit of grease in them prior to driving.
« Reply #16 on: April 07, 2015 - 10:01:08 AM »
The ball joint is loose in the control arm. It can be moved up about .25 before it hits enough interference to prevent it from popping all the way out.
« Reply #17 on: April 07, 2015 - 03:39:37 PM »
Oh, I thought he meant loose in the ball joint housing, like worn out.  :-\ ?
« Reply #18 on: April 07, 2015 - 08:33:12 PM »
OK
 You need to replace the upper control arms  or you could it then them down & weld them but the ball joint & arm will both be junk next time they wear out .
« Reply #19 on: April 07, 2015 - 09:36:01 PM »
OK
No No No!
Some confusion going on. Sorry about that.
The upper control arm is fine.
The ball joint is frozen inside to the upper control arm where it screws in.
I used a 3 foot cheater bar and it wouldn't budge. I'll use Brad's suggestion of heating it up.
The shaft that comes out of the ball joint has quite a bit of play in it after only 500 miles.
That is the only part worn.
« Reply #20 on: April 08, 2015 - 09:08:34 AM »
Okay, my mistake. I thought the entire ball joint was loose in the arm.
« Reply #21 on: April 08, 2015 - 01:04:31 PM »
if the ball joint is frozen then I assume these are not new ball joints ?
Offline BFM_Cuda
« Reply #22 on: April 08, 2015 - 04:08:22 PM »
I would replace the upper ball joints, assemble the spindle without the dust boot and torsion bars, and cycle the suspension with a bottle jack and see if the balljoint shaft is hitting the edge of its cage before you reach full travel (or if its even close at full travel).
« Reply #23 on: April 08, 2015 - 10:18:47 PM »
they were new but sat for a long time.
I even soaked it in evaporust before just in case.
« Reply #24 on: April 08, 2015 - 10:23:50 PM »
they were new but sat for a long time. The part of the ball joint where it screws in is frozen. Not the inner portion of it.
« Reply #25 on: April 12, 2015 - 12:20:33 AM »
As for the suborn one... maybe a little heat?  :dunno:
That did the trick!
I used a pencil flame Oxy/Propane torch and it unscrewed with ease once heated.
And then to put the rubber boot seal on...
I firgured just put the ball joint socket on upside down and force it up onto the ball joit.
Worked perfect!
« Reply #26 on: April 12, 2015 - 08:58:43 AM »
 :2thumbs:  Great it worked out ! Moog replacements? The new ones should screw in with "some" resistance.
« Reply #27 on: April 12, 2015 - 11:12:02 AM »
Yes Moog.
« Reply #28 on: April 12, 2015 - 01:23:05 PM »
If I run the taller F,M,J, spindle do I have to: (mandatory) use the Moog offset bushings?
I have Polyurethane non offset UCA bushings in it now.
« Reply #29 on: April 12, 2015 - 02:30:42 PM »
No the offset bushing just allow you to get more/enough caster.
