Mini Starters.
Author Topic: Mini Starters.  (Read 9044 times)
Offline berna4406
  • Sinister
Mini Starters.
« on: April 05, 2015 - 01:29:10 AM »
Which Mini Starter are you guys running in your big blocks. Thanks Sam
Offline CudamanTom
Re: Mini Starters.
« Reply #1 on: April 05, 2015 - 10:53:00 AM »
Sam,
Here is a link for ya. I haven't had any problems with mine.
http://www.cuda-challenger.com/cc/index.php?topic=92662.msg917174#msg917174
Tom
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline BIGSHCLUNK
Re: Mini Starters.
« Reply #2 on: April 05, 2015 - 11:52:06 AM »
New Denso from our friend at Roseville  :thumbsup: Cranks my Hemi w NO isuues...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BS CUDA
Re: Mini Starters.
« Reply #3 on: April 05, 2015 - 05:20:15 PM »
Just removed another Power Master not less than an hour ago. Was only 2 years old and likely less than 100 starts. Ordered a MSD yesterday - we'll see how that turns out.
Re: Mini Starters.
« Reply #4 on: April 05, 2015 - 07:49:10 PM »
Iuse ones from the wreckers , $20 used , change the contacts for $5 & they last !
Re: Mini Starters.
« Reply #5 on: April 05, 2015 - 08:35:30 PM »
Mid 90's Dakota or Ram.
Re: Mini Starters.
« Reply #6 on: April 05, 2015 - 08:46:17 PM »
Powermaster makes an awesome product !!
 NOT
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Mini Starters.
« Reply #7 on: April 05, 2015 - 08:50:41 PM »
I bought this one through Amazon and it has been good so far. From UR Quality Solutions
She cranks and sounds good without any fuss. Most Parts store starters I've had always end up sounding like crap.
http://www.amazon.com/New-Starter-Chrysler-53005984-17466/dp/B00C1M23CS/ref=lh_ni_t?ie=UTF8&psc=1&smid=A3OOW04DXE262V
http://urqualitysolutions.com/New-Starter-128000-7810-53005984-9712809-781-S2403-SR6504N-17466-17466.htm?categoryId=-1
Looks like this one but mine came with copper terminals.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline djw383
Re: Mini Starters.
« Reply #8 on: April 05, 2015 - 08:51:08 PM »
I have hedman headers I wanted to use and I could not fit a mini starter but could fit an oem starter....go figure. If the motor is out, test fit while on the stand whatever you use.
Offline footin70rt
Re: Mini Starters.
« Reply #9 on: April 05, 2015 - 09:52:03 PM »
Got one from an early 90's Dakota, been running it for 8 years.  :bigsmile:
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline berna4406
  • Sinister
Re: Mini Starters.
« Reply #10 on: April 06, 2015 - 12:37:38 AM »
Thanks for the input guy's. I  put a new 499 in my 71 Charger R/T and installed my old Tilton Super Starter that has been in the car for 20 years.I went to crank the motor over and it was cranking good almost had the motor running for the first time installed in my car.Then the starter stopped fully engaging.Pulled it out and checked everything .Everything looked good so reinstalled samething happened.So looking into just replacing the starter.Had sent it into Tilton 13 years ago for rebuild but they do not offer that service anymore.Ken at Tilton did refer me to a shop but daid that any Starter/Alternator rebuild dhop can rebuild them as long as they are  familar with the Hitachi Starters. Thanks guys
Offline brasil
Re: Mini Starters.
« Reply #11 on: April 06, 2015 - 08:35:52 AM »
is the starter for the 90-93  Dakota ...  the right one for my 340 cui engine ?
I Think I need a new starter in the very near future...because the downpipes are very very ´close the the OEM starter, and when the engine is hot...the starter seems to be a little  weak...
Greetings Jurgen
..p.s   is there a specific Part No ? Or engine size ?  Or just fpr a 90-93 Dakota  ?
Offline Bart
Re: Mini Starters.
« Reply #12 on: April 06, 2015 - 10:23:44 AM »
I used the one out of a Dakota from NAPA lifetime for my 383 fit well after you remove the side cover for the terminals.
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline brasil
Re: Mini Starters.
« Reply #13 on: April 06, 2015 - 01:59:33 PM »
..so if I want to use this starter..I have to modify the terminals ? right ?
I am asking, because I live in Germany...so if I order some parts from the US  ...the Transport is the main issue   :(
I found starters on the rockauto webside ... from REMY   DELCO   BOSCH aso..
Greetings Jurgen
Re: Mini Starters.
« Reply #14 on: April 06, 2015 - 02:05:36 PM »
Look at the above picture.  That is the style of starter used on the Dakota's and Ram's.  The black piece that has the terminals on it can be removed from the starter.  There is a plastic cover that you pop off to un bolt that piece.  Then, your stock starter wiring will connect to what's left.
