Mini Starters.
Author Topic: Mini Starters.  (Read 9046 times)
Offline RCCDrew
Mini Starters.
« Reply #15 on: April 06, 2015 - 02:08:25 PM »
The denso starters off any year magnum truck works awesome. There are a few magnum starters that won't work, like Jeep Grand Cherokee starters.
Like CP said, when they start clicking and not wanting to crank, replace the copper contacts and they will be good as new.
« Last Edit: April 06, 2015 - 02:10:09 PM by RCCDrew »
Offline brasil
Re: Mini Starters.
« Reply #16 on: April 06, 2015 - 02:39:33 PM »
Thank you  burdar , thank you RCCDrew
Now I can order a starter from Rockauto...
I Think a REMY or a Bosch will be o.k ...too     because RA doesn´t list Denso... ...
Greetings from Germany
Juergen
Offline RCCDrew
Re: Mini Starters.
« Reply #17 on: April 06, 2015 - 03:13:13 PM »
They used to be called Nippon Denso ...
Offline brasil
Re: Mini Starters.
« Reply #18 on: April 07, 2015 - 01:39:52 PM »
bought a  REMY Gold ...   should be shipped tomorrow.
Greetings Jurgen
Offline brasil
Re: Mini Starters.
« Reply #19 on: April 10, 2015 - 05:31:25 PM »
Starter arrived this morning....
Installed him this afternoon...   WOW    just plug and play..    works like a dream !
Thank you Guys for the advises
Greetings Juergen
Offline RCCDrew
Re: Mini Starters.
« Reply #20 on: April 10, 2015 - 06:26:08 PM »
Awesome!
Offline BS CUDA
Re: Mini Starters.
« Reply #21 on: April 10, 2015 - 10:20:34 PM »
Update - while the MSD is a little bit pricey it works, sounds and fits fantastic. It is rotatable but found the delivered assembly worked best. Just sneaks through the TTI's with the wheel off through the opening.
Offline Gumby
Re: Mini Starters.
« Reply #22 on: April 19, 2015 - 10:25:15 PM »
Less than $20 from the scrapyard. Original Mopar on a Dakota P/U. Works just fine. May have to remove the plastic thingy, which is just an electrical extender/relocator/adapter. The original posts on the starer are inside of it.
At that price, you can buy 2-3-4 and have spares for when the original fails. STILL saving money on those high dollar ones. The Junk yard ones work as good as the new high dollar ones. For hundreds less.
On that note, I bought a Powermaster High Output Alternator for my Suburban.Bearings went out in the original. Maybe 10 years ago. It has served me well. I put in an Optima Red Top battery in 2001? Maybe 2000, which I bought in '98 or so.
It is STILL going strong! lol. I can't believe it. My everyday driver. Been ran down a few times, jump started a few vehicles, and it keeps going. Severe cold, severe heat, long range short range - no matter what, it has kept going.
I hear the new ones aren't as good? no idea if that's true. I'm a believer in them, for sure.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Re: Mini Starters.
« Reply #23 on: April 19, 2015 - 11:02:01 PM »
They won't last very long.    :2cents:
I saw numerous returns on Optima's when I was selling them before.
Re: Mini Starters.
« Reply #24 on: April 20, 2015 - 04:07:27 PM »
In daily use an Optima will last , let it sit & go dead & you are replacing it . My red top lasted 13 years
Re: Mini Starters.
« Reply #25 on: April 20, 2015 - 08:54:38 PM »
I had the same experience. Fine in my daily driver , but my "seasonal car" it died and wouldn't hold a charge after that.
Offline Code3
Re: Mini Starters.
« Reply #26 on: October 21, 2015 - 11:29:30 PM »
My Starter is clicking now. How do I replace the contacts? Can I buy those at a parts store? I don't want to have to pull the headers and put a new starter in. Thanks for the help!
Offline 73440
Re: Mini Starters.
« Reply #27 on: October 21, 2015 - 11:45:16 PM »
This video is shown doing the work off the engine,
http://nationsautoelectric.com/densoparts.html
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline GreenFish
Re: Mini Starters.
« Reply #28 on: October 22, 2015 - 12:50:04 PM »
Yes if you have an optima, keep a tender on it, I dont use them anymore. I just use the Autozone AGM Platinum. I went through an Optima every year. I still had the old replacement warranty  but its not as good anymore. So I switched to the AZ AGM much cheaper.  I like it much better, but I also keep a tender on it.
Offline HP_Cuda
  • Mopar or No Car!
Re: Mini Starters.
« Reply #29 on: October 23, 2015 - 01:14:25 PM »
I recently tossed out a Optima and replaced it with an Interstate.
No problems whatsoever!
 :cheers:
