Author Topic: Fuel Pump  (Read 802 times)
Offline cudabob496
Fuel Pump
« on: April 05, 2015 - 04:03:08 AM »
The output pressure of my mechanical fuel pump
seems to be decreasing slightly. It is about 10 years old.
Should I replace the whole pump, or just replace the rubber diaphragm?
2011 Kawasaki Z1000
Offline AussieMark
Re: Fuel Pump
« Reply #1 on: April 05, 2015 - 04:33:09 AM »
Pull it apart and see what's going on and take it from there.
Offline cudabob496
Re: Fuel Pump
« Reply #2 on: April 05, 2015 - 06:10:46 AM »
I checked Summit, and they have replacement diaphragms for only a few models of
mechanical fuel pump. But I agree, take it off, check model number, and go from there.
I noticed a decent big block fuel pump is about $120. Thing I'm wondering about, is will a new
$35 diaphragm get me another 10 years, or is there something else that goes bad about this time?
What have others experienced?
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
Re: Fuel Pump
« Reply #3 on: April 06, 2015 - 10:52:43 AM »
usually, mechanical fuel pump diaphragms are good for at least 50,000 miles (at least in the old days) and then they start to show signs of fatigue which leads to cracks and the failure to pump.
There are also a couple of springs under the diaphragm and I suspect output pressure depends upon the condition of the big spring.
I would not be surprised to find that ethanol in the gas will shorten the life of the diaphragm as well these days
Offline HP_Cuda
  • Mopar or No Car!
Re: Fuel Pump
« Reply #4 on: April 06, 2015 - 01:05:40 PM »
You can always go electric!!!
 :bigsmile:
