Author Topic: MSD coils  (Read 4482 times)
Offline 3D
MSD coils
« on: April 05, 2015 - 09:45:05 PM »
Anyone using the G3 2006 and newer MSD twin plug coil packs?
Id like to know if i can use these on a 2004 hemi. I  would think the only difference is the electrical  plug?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: MSD coils
« Reply #1 on: April 05, 2015 - 10:15:18 PM »
Is it a truck motor?  Cuz if I'm not mistaken, the pre-06 truck motors used a coil that fed 1 cylinder on each bank, the one directly underneath it, and one directly opposite it on the other bank, soy thought would be that the computer would tell it to fire differently?  I'm not sure
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline 3D
Re: MSD coils
« Reply #2 on: April 06, 2015 - 02:29:58 PM »
Yes, it is exactly as described, 2004 truck 5.7.
I'm wasn't sure if it fired the two plugs at the same time?
The newer coil packs just make for a cleaner install.
Offline roadman5312
Re: MSD coils
« Reply #3 on: April 06, 2015 - 03:33:34 PM »
               They were set up to fire 1 plug on the compression stroke, the opposite bank plug on exhaust stroke. Emmisions. They later found it was useless and eliminated it.
Offline 3D
Re: MSD coils
« Reply #4 on: April 06, 2015 - 04:26:50 PM »
That is exactly what I thought.
So I don't see any reason Why I couldn't adapt the newer coil to an older motor Just by changing the electrical connector. I'd just have stronger spark/cleaner burn?
Thoughts???
Offline roadman5312
Re: MSD coils
« Reply #5 on: April 06, 2015 - 04:34:40 PM »
When I converted a 5.7 from EFI to dual quads we used the shorty plug wires so each coil fired the same 2 plugs in each cylinder. However we had to use an MSD controller to fire the coils for timing reasons. The kit came with cam and crank sensors, the wiring harness and ecm. About 1400 bucks.
Offline 3D
Re: MSD coils
« Reply #6 on: April 06, 2015 - 09:01:34 PM »
what year is your motor and do you what you timing is?
Offline roadman5312
Re: MSD coils
« Reply #7 on: April 07, 2015 - 06:59:00 AM »
We had the laptop hooked up to the MSD box, total timing was 35 degrees @ 3000 rpm. Base timing was jumping all over the place based on the readings the ecm was getting from the MAP sensor. I replaced the MAP with a new one, had the same results. However it doesn't effect performance, idles smoothly, and has way more power.
Offline 3D
Re: MSD coils
« Reply #9 on: April 08, 2015 - 01:39:15 PM »
Yes, but it only fires one plug.
Offline roadman5312
Re: MSD coils
« Reply #10 on: April 08, 2015 - 03:22:00 PM »
They both fire 2 plugs, the 03-05 style you would use the shorty plug wires.
Offline 3D
Re: MSD coils
« Reply #11 on: April 08, 2015 - 05:53:23 PM »
Yes, but the 06 and new would make for a cleaner install. I think all I need to do is change the electrical connector.
Offline roadman5312
Re: MSD coils
« Reply #12 on: April 09, 2015 - 06:48:27 AM »
                              definately a cleaner install
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
Re: MSD coils
« Reply #13 on: June 05, 2015 - 04:42:24 PM »
You would need to convert the harness and change valve covers to the new style
https://www.modernmuscleperformance.com/product/57l-hemi-coil-pack-conversion-connectors
Offline 3D
Re: MSD coils
« Reply #14 on: June 06, 2015 - 04:48:10 PM »
Thanks, that's exactly what I'm after.
