Author Topic: 3 peice trunk trim fit and finish?????  (Read 825 times)
Offline lulurocks
« on: April 06, 2015 - 09:24:36 PM »
Guys,
I need to buy a 3 piece molding set for the trunk and quarters to make sure everything is lined up nice before  I start prime and paint .
   Has anyone had  a good or bad experience  with the Rossville auto parts set?   Or recommend an alternative
Thanks
Offline anlauto
Re: 3 peice trunk trim fit and finish?????
« Reply #1 on: April 06, 2015 - 09:29:51 PM »
As long as your trunk lid is lined up, the trim can be adjusted slightly to insure alignment once installed. I would say there is no need to trial fit before paint. :2cents:
Offline dakota
« Reply #2 on: April 06, 2015 - 09:48:48 PM »
I bought and installed the 3 piece rear trim from Rossville on my 70 Challenger.   The only issue I has was breaking a couple of the little wire springs on the mounting hardware.   I was able to re-use a couple from the original set, so no big deal.   Otherwise, I'm a very happy customer of Rossville.
Offline lulurocks
« Reply #3 on: April 07, 2015 - 08:29:53 PM »
Thanks Alan and Dakota for your   :2cents:
Ken
