Author Topic: speedo needle jumps  (Read 1031 times)
Offline brasil
speedo needle jumps
« on: April 07, 2015 - 02:14:29 PM »
Helo my friends
I have ( or better my Chally has ) a problem with the speedometer... if it is cold, the speedo jumps up and down....while driving slower than 50 mph
if I run the car for more than 10-15 minutes it is getting better...  changed the speedo cable..  but still the same
Any Ideas ?  Should I remove the speedo...to put some "Gun Oil " to the gears... ?
Greetings Jurgen
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: speedo needle jumps
« Reply #1 on: April 07, 2015 - 05:06:31 PM »
usually that is caused by a dry inner cable. I know you replaced it but did you lube it first? Lots of cables come with the bare minimum lube so they don't leak on the shelf. Also I have seen the inner cable being too long cause this too. Just cause its new don't mean its right.  Don't use gun oil on the speed o use grafite same with the cable too
Offline brasil
« Reply #2 on: April 08, 2015 - 02:37:43 PM »
...  ups     I used gun oil
Now the jumping / bouncing is gone....   I also routed the cable in a different way
Can the gun oil demage something ???? :clueless:
Greetings Juergen
Offline OUTLAW
« Reply #3 on: April 08, 2015 - 03:17:13 PM »
not really damage but oils draw dust which turns to goo !  a dry lubricant is always best for things like this
Offline brasil
« Reply #4 on: April 11, 2015 - 05:23:01 PM »
thank you
I will put some grafit powder inside the cable...the next days
Greetings Jurgen
