I've had the mini laying around here for years, it was for my ProStreet Duster that I'm building. I'm pretty sure I got it from Mancini or maybe Summit, it came with heat shields which was nice because alot of them don't. It was hard as hell to get my old starter out without removing a bunch of stuff. I had to turn the front wheels all the way to the right, remove that plastic dust cover thing from the frame, then I stood the starter on end and slipped it past the suspension and headers. If that starter had one more coat of paint on it, I don't think it would have made it :laughing:
The mini wasn't much better, I had to remove the heat shield from one side just to get it past everything, then I put the shield back on.
If you do get a mini, it might be a good idea as soon as you get the mini past the suspension to install the two wires to it(the other ends are disconnected so you can drop the wires lower), THEN bolt the mini in place. Because the minis two poles are on the top, it made it VERY hard to get around two of the header tubes, and the steering shaft to install the wires.
