Author Topic: A couple issues with new door panels  (Read 18511 times)
Offline Challenger6pak
Re: A couple issues with new door panels
« Reply #45 on: April 10, 2015 - 06:44:55 PM »
I don't know why but sometimes these things happen.
Offline jimynick
« Reply #46 on: April 10, 2015 - 07:33:35 PM »
I believe the PC version is "ka-ka occurs". That doesn't mean it's not a PITA nonetheless!  :pullinghair:
Offline CHL2T
  • Handle it, man!
« Reply #47 on: April 11, 2015 - 01:27:01 PM »
I'm really surprised that Dave from Roseville hasn't responded to this thread yet.
I got my panels from him and as stated in another thread, the rears are perfect but I haven't tried the fronts yet. I may dink with them today when it warms up a bit....
Offline blown motor
« Reply #48 on: April 11, 2015 - 01:44:34 PM »
CHL2T, did you get yours from Roseville? Let me know how they fit.
I put the driver's panel on this morning. It fit a bit better but still not flush.  :dunno:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #49 on: April 11, 2015 - 02:16:11 PM »
Murray.
did you clip the bottom before screwing the sides. When you talked to Jon yesterday you did not have the lower clips in. We have sold 100's of the panels between cuda and challenger and have had ZERO issues. in the early run the upper rib reinforcement needed to be trimmed as that was hitting the shell creating a push out condition. Which maybe a rare case with this panel. The panel it self looks to be too high as it isn't seating well on the door frame.  maybe the door frame is bent or distorted some how.
So for those of you that haven't installed these yet don't panic.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline blown motor
« Reply #50 on: April 11, 2015 - 02:37:02 PM »
Dave, I have not clipped the bottom. With all due respect, I do not see how clipping the bottom will cause the panel to spread so the sides slip over the shoulders of the door famework. As far a being to high, the screws lined up perfect horizontally. All eight screws on each panel are started but I have not tightened them completely because that will mess with the straightness of the outer flange of the panel. I am being very gentle here, I want it perfect when it's done. I have them both on and they look awesome!!  :bananasmi  I am working in a cool shop (50*). Some day when I have time I'll park the car out in the sun and let things warm up good inside. Maybe I'll gain a whisker of expansion and some flexability and get them to seat properly. Right now I don't want to force things. We'll get this right.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #51 on: April 13, 2015 - 01:55:25 PM »
the holes are slotted on the door shell and you may not be able to use the original threaded hole, the bottom should be clipped in Before you screw in the sides. see picture for ONLY know fitment issue
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #52 on: April 13, 2015 - 01:56:53 PM »
also. if the upper clips where the arrows are, are NOT seated properly you will have this issue of the panel being too high.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline cordodge
« Reply #53 on: April 13, 2015 - 02:56:04 PM »
I installed front and back panels, i had to trim a little bit as i had dyna mat directly behind the panels but after a little tweeking they seem to fit fine  :dunno:
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline JayBee
« Reply #54 on: April 13, 2015 - 06:51:32 PM »
I've got a set of the very first issue of Metro's Cuda door panels and have test fitted them to a couple spare doors in the basement. Those circled areas that Dave posted all had to be trimmed on mine to look like my original door panels. Still haven't put them on the car because they'd look out of place with the old convertible rears.
John
1970 Barracuda convertible
2014 Toyota Avalon
