Author Topic: 1 poly-loc motor mount?  (Read 4363 times)
Offline schtick
« on: April 09, 2015 - 07:02:48 PM »
Any reason why I can't use the poly-loc motor mount on the drivers side only? It's mostly a streetcar and I would like to keep the vibrations to a minimum.
Offline cudabob496
Re: 1 poly-loc motor mount?
« Reply #1 on: April 09, 2015 - 07:34:04 PM »
I use standard mounts, but have a Schumacher Torque Strap on the drivers side.
Polylocs are known to fail on occasion.
2011 Kawasaki Z1000
Offline ToxicWolf
« Reply #2 on: April 09, 2015 - 07:36:35 PM »
I will be using one on the drivers side with the new hemi.  It maintains the original look.  :2cents:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: April 09, 2015 - 07:59:50 PM »
I have heard poly locks can cause a bad vibration in the rails.  I used mag mounts from Mancini and they worked great.  Installing them again for the 440 in the Charger.
Offline cudabob496
« Reply #4 on: April 09, 2015 - 08:38:13 PM »
with a torque monster Hemi, I'd be inclined to have a torque strap.
If a mount breaks, you could have major damage.
http://www.bing.com/images/search?q=schumacher+torque+strap&view=detailv2&&&id=78E1CC297A44B865ECD2E679DCE523D6B546E677&selectedIndex=1&ccid=8BstqT2O&simid=608049704710047196&thid=JN.yp%2bPoCu9ZPvwyZv5PrAWaw&ajaxhist=0
2011 Kawasaki Z1000
Offline schtick
« Reply #5 on: April 11, 2015 - 11:22:12 AM »
Forget it. I put just the driver side in and with the shaker it looks stupid. The shaker on the drivers side is sitting up very high on the other side it's very low so I'm going to put them both in.
Offline Kevin71
« Reply #6 on: April 12, 2015 - 04:49:35 PM »
Is there a difference in the height of the engine on poly's.  I have them in my 71 challenger with a 440.  Have been having a problem of the center link rubbing the pan.  Are they lower or taller than stock?
Offline schtick
« Reply #7 on: April 12, 2015 - 10:23:30 PM »
My engine sits a little higher than with the stock mounts. But I'm thinking that the extra 1/4 -3/8" is because the old mounts settled.  My car is a 70 Cuda 440 and the only extra vibration I notice is at 65 mph. Sort of a buzzing not really a vibration through the steering wheel. Barely noticeable.  Love the ploy-locs.
Offline cudabob496
« Reply #8 on: April 12, 2015 - 11:48:33 PM »
All that Hemi torque, on one little drivers side motor mount!!  If it lets go,
Twist City!!
« Last Edit: April 13, 2015 - 04:40:44 PM by cudabob496 »
2011 Kawasaki Z1000
Offline ToxicWolf
« Reply #9 on: April 13, 2015 - 04:10:44 PM »
I looked for the mag mounts for an e-body that works with a hemi but couldn't find them.   :crying:
