Author Topic: Headers for 70 Chally 318  (Read 8057 times)
Offline Jimmy C
Re: Headers for 70 Chally 318
« Reply #15 on: April 12, 2015 - 11:00:27 AM »
Thanks for all the input fellas
70 Challenger
Menifee, California
Former San Diego resident
Offline cbrxxtreme
« Reply #16 on: April 14, 2015 - 08:14:41 AM »
Just for sound, i know it won't do much in terms of HP on a stock 318. I plan on making it dual exhaust at the very least. If it's a pain, i don't mind keeping the stock manifolds and just going dual exhaust.
 I had duals made, and it is a very tight bend on passenger side over the oil filter, and over the steering. The worthless tit that did mine didn't do a good bend and it hit the idler arm on the steering linkage (the arm that is parallel to pitman arm). Thus ruining that piece, when I replaced it with a lil beefier one it hit so bad the car would not steer. So have another shop try to fix the exhuast right, or a pair of $150 headers... was a no brainer for me. Yes the steering has to run thru the headers, and yes they will bottom out if you don't raise the front end a bit. As for crushed flat... I live in an area whit tremedous frost heaves, and haven't had that problem. Besides, how do all those lowered cars get around without dragging something.? And I can buy a lot of inexpensive headers for the prive of the "good ones".   My car is a driver, not a show car.    :2cents:
Dads 1 owner 1970 Barracuda convertible.
Offline AussieMark
« Reply #17 on: April 15, 2015 - 05:44:39 AM »
I was looking at the new repro 340 HP ex manifolds that Year One sell part # AE340 for $600 a pair they have the correct casting #s and are cheaper the rusty used ones on Ebay what do you think of them?
« Reply #18 on: April 15, 2015 - 09:19:00 AM »
I've used these inexpensive wrap around headers on several builds and never "smacked" a tube hard enough to flatten it significantly. I've certainly drug them over more than an occasional speed bump, but I've also seen a fair number on cars or in swap meets that have had half the tube diameter smacked flat. Driver skill I suppose.
« Reply #19 on: April 23, 2015 - 12:04:39 PM »
Good option , also the Magnum truck manifolds will fit & flow well too
