Author Topic: Do E-Body Rear Interior Side Panels Interchange?  (Read 1314 times)
Offline Old Moparz
  • Larks' Tongues In Aspic
« on: May 15, 2005 - 04:37:48 PM »
I was looking at some photos but can't tell for sure whether Challenger & Barracuda rear, interior, side panels are the same. These are the molded plastic panels at the left & right sides of the rear seat. They look the same, but I would like to know for sure if they are before I start hunting for a set & buy the wrong ones.
I'm not interested in the aftermarket set, they don't look right to me & a lot of people complain about fit also.
Thanks if anyone can help, Bob
Newburgh, New York - 12550
  Walking is good for you. It's documented that for every minute you exercise, you add a minute to your life. This enables you to spend an additional 5 months in a nursing home at $5000 per month.
Re: Do E-Body Rear Interior Side Panels Interchange?
« Reply #1 on: May 16, 2005 - 01:22:06 AM »
they are different , the treim lines in the panels are different & the Cuda uses a sail panel , the chall does not so they ar different at the top edge as well & I believe the cuda is shorter aslo as the cUda has a 2" shorter wheel base
Offline Old Moparz
« Reply #2 on: May 16, 2005 - 08:05:44 AM »
Thanks CP. I did manage to come across some pics on a website catalog & eBay, where I saw the differences you are saying. I had a rear set from a junkyard in my shed for over 15 years & sold them thinking I'd never use them. Now that I have a Barracuda with cracked rear panels.....  ::)
« Reply #3 on: May 16, 2005 - 01:35:52 PM »
typically this si exactly what happens
Offline cudacruzer
« Reply #4 on: June 27, 2005 - 07:35:56 PM »
(1) Door panels are the same for Cuda Vert and Coupe, or no? (2) Rear side panels are the same for Cuda Vert and Coupe, or no (probably no)?  Thanks.
ROB BRIGGS/Atlanta
'69 SS/RS Camaro Convertible (Numbers Matching)
Bikes: 2005 Custom S&S 145" Pro-Street /2005 BMW K1200LT
3 Kids/2 Dogs/2 Cats/Only 1 Wife
"Better to Wear Out Than To Rust Out"
« Reply #5 on: June 27, 2005 - 07:37:57 PM »
I believe the door panels are identical , the rear iner 1/4 panel arew totally different for a convert
