Author Topic: Help Before my Wife Kills Me  (Read 23361 times)
Offline 73440
Re: Help Before my Wife Kills Me
« Reply #60 on: April 16, 2015 - 09:35:21 PM »
Thanks;
 Does it smell after shut down? Sure, but not as bad. Never will be like her minivan.
That's a good thing though.
Glad ya got it going.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Strawdawg
    • Vortex Buicks
« Reply #61 on: April 17, 2015 - 09:38:31 AM »
should have a bit better power at light throttle, I would think.  If it is still blowing black smoke, you may want to take it a bit leaner yet.
Offline 73_Cuda_4_Me
« Reply #62 on: April 17, 2015 - 11:33:24 AM »
 :2cents: Intake valve stem seals? Oil leakdown can cause black smoke at startup, too...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline dpcd67
« Reply #63 on: April 17, 2015 - 12:50:34 PM »
 Should have more power at light throttle?  What makes you say that? I have to be careful to keep the tires on the ground as it is.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline Strawdawg
    • Vortex Buicks
« Reply #64 on: April 17, 2015 - 01:17:59 PM »
Leaner mixture gives more power whether you need it or not
Offline dpcd67
« Reply #65 on: April 17, 2015 - 01:57:54 PM »
What makes you think more lean than two stages will give more power; there has to be a limit?  I know, try it and see; right?
« Last Edit: April 17, 2015 - 01:59:30 PM by dpcd67 »
1963 Dodge M37 (3)
I ain't done yet.
Offline Strawdawg
    • Vortex Buicks
« Reply #66 on: April 17, 2015 - 02:23:24 PM »
Either I am unable to communicate well, or you are putting words in my mouth. :)
Let me try this once again.
By going leaner, the car should have picked up a little power.  That means in the past tense.  After you made the changes that you did, the car should have picked up a little power.  Whether you wanted more power, or not, is not the question...it is just a fact.
Now, you also said it is  blowing less black smoke.  To me, I took this to mean it is still blowing some black smoke so this would indicate that the car is still on the rich side.  Therefore I said you could take it a bit leaner-meaning it was your choice.   This was to try to further reduce the black smoke.
Probably, I should have not bothered to comment but sometimes I don't know when to stop...but now I do  :D
Offline dpcd67
« Reply #67 on: April 17, 2015 - 03:00:42 PM »
Ah, I see; I thought you meant it should have a bit better better power than it does now, after I made the changes; I thought you watched the video of it and determined that.
Yes, it does have more power than it did before. The video shows the exhaust now; it is vastly improved over what it was.
1963 Dodge M37 (3)
I ain't done yet.
Offline Strawdawg
    • Vortex Buicks
« Reply #68 on: April 17, 2015 - 03:06:58 PM »
I'm glad it helped...peace at home is nice :)
Offline dpcd67
« Reply #69 on: April 17, 2015 - 06:02:04 PM »
Yes, it definitely helped in exhaust quality, and I did (I did not expect it) gain a bump in power. Thanks to all who offered advice; now I won't have to change carbs.  Edey carbs might not be junk after all.
1963 Dodge M37 (3)
I ain't done yet.
Offline Katfish
  • 70 Challenger
« Reply #70 on: April 17, 2015 - 08:55:28 PM »
Did you have to change a gasket when you pulled the carb apart for the jets?
Offline dpcd67
« Reply #71 on: April 17, 2015 - 10:24:51 PM »
No; the old one was fine and was not stuck to either side but if they get torn or are deteriorated then they would need replacement. This carb is only 7 months old.
1963 Dodge M37 (3)
I ain't done yet.
« Reply #72 on: April 20, 2015 - 04:02:54 PM »
you should virtually no black smoke , maybe grey when you floor it , lean it more & watch plug color
Offline dpcd67
« Reply #73 on: April 21, 2015 - 11:26:01 AM »
It will be easy to go to "3 stages" lean, just by re-installing the original rods and leaving the .092 jet in. I assumed you watched the video.
1963 Dodge M37 (3)
I ain't done yet.
« Reply #74 on: April 21, 2015 - 01:13:57 PM »
Looks more like white or blue smoke than black smoke, based on what I think I see in the video.
