Author Topic: Throttle cable advice  (Read 805 times)
Offline Sly_drums
« on: April 12, 2015 - 04:54:39 PM »
Throttle cable in my Challenger is showing signs of wear and needs replacing.
I've heard good things about the Lokar systems but there are so much references...
Would you get a stock replacement cable or an aftermarket one ?
The car is a 71 383 automatic Challenger, with 570 cfm Holley Street Avenger carb (will be replaced by a 750 soon), stock kickdown linkage.
Thanks !
Offline roadman5312
Re: Throttle cable advice
« Reply #1 on: April 12, 2015 - 04:58:58 PM »
                               Stock replacement   :2cents:
« Reply #2 on: April 12, 2015 - 06:25:54 PM »
Offline BS CUDA
« Reply #3 on: April 12, 2015 - 07:22:46 PM »
My stock kickdown linkage was all bent and worn out so my choices were limited on a short time frame. I went with the Lokar and it works fairly decent and was not horrible to setup. I now have a decent working accelerator cable and kickdown.
