Author Topic: challenger glove box knob/ lock  (Read 2874 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: April 12, 2015 - 09:49:20 PM »
Hello all
I have a question about the assembly that secures the glove box lid. I have the knob (long chrome piece you turn to open the glove box with the tumbler) and the key that goes with it. I need the housing that the tumbler goes through. Is that all I need? how does the tumbler attach to the housing? does anyone have one for sale? I need the "catch" part as well.
thanks!
Re: challenger glove box knob/ lock
« Reply #1 on: April 12, 2015 - 10:31:15 PM »
The outer housing screws into the inner glove box door frame & then the lock slides through the door into the out lock housing . there is a retainer tab near the key head if you push it down & slide the key in the tab stays down then insert the lock into the housing & remove the key & the tab pops up holding the lock cyl in place , to remove it again the cylinder needs to be in the locked position use a paper clip or jewellers screwdriver to depress the retainer while sliding the key in & the cylinder can be removed again .
« Reply #2 on: April 12, 2015 - 10:35:44 PM »
ok cool! so I just need the housing. Thanks!
Offline JayBee
« Reply #3 on: April 13, 2015 - 09:33:17 AM »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline anlauto
« Reply #6 on: April 13, 2015 - 03:15:25 PM »
EBay is your friend   http://www.ebay.com/itm/NOS-Glove-Lock-Case-Mopar-Challenger-Barracuda-70-71-72-73-74-/351301070123?vxp=mtr&hash=item51cb2ced2b  :smilielol:
I was looking at that one. Just as soon as I buy one, I will find mine. That's usually the way it goes.
Offline anlauto
« Reply #7 on: April 13, 2015 - 03:36:22 PM »
Probably find a whole glove box door cheaper...I think there was a guy on Mofarts.com selling one cheap
« Reply #8 on: April 13, 2015 - 04:21:08 PM »
i wonder if they have the key? I'll check it out.
